Jaco Rubberz
Regional Moderator
However, if you tend to try to get several runs out of a set (for club racing and practice sessions) these tires will leave you dissapointed for sure. I have found many that with other brands of tires (varying compounds) even when the tire has dropped off in performance3-6 runs, its still worthy of 4-8 more runs. This is not the case with the Jacos though. In the 12 sets I have ran none of them have been worth more than 3-4 runs. I'm not just speaking of the point were they loose a couple tenths. I'm talking about total loss of shape (completely gone). Most of this testing has been with stock motors, (asphalt). In one case I put in a BL 4.5, the tires (28's) had only three runs with a stock motor on them at the time. Two runs later the webbing (strands) and inserts were showing.
So do they perform? In my opinion, yes. Are they the best choice for the weekly racer? Not this one.
Gravity RC
I have been running them a ton on carpet and wear is not an issue, my self and Billy Easton had sets that we ran over 20 times and when we went to
put new ones on i went the same speed and billy went not even a full tenth faster. If their is one thing i know about rubber tires its that results will vary depending on the track.. for example at the reedy race Rp30s are honestly 3or4 tenths faster the first run than on the second, but i have also seen a track where they dont drop off much.
Gravity RC
Oh I see, I think that with a track like that you may want to try the orange's I can understand your results now. Even though the blue is a 32, on some tracks they have such good grip that you may need to go harder than you would think. I think that you would really like the orange's.
Gravity RC
syndrome: yea, they wore very well at trackside. I know that the results will vary depending on where and how they are used but i have had no problems
Here is another issue to consider: most of the tires available right now are THIN wall tires. We have since changed the mold to decrease the airgap and thicken the tire. This will result in much more life on abrasive surfaces. The tires for Vegas are going to be thick wall as are all the tires we get in from here on out.
The majority of the feedback we have gotten is that they last a very long time and get better as you run them. However, on abrasive surfaces, the thin wall tires wear out in about 3 runs. The thick ones are much better.
Regional Moderator
It will be a running change. Same part numbers.
Thanks for the reply's guys. They sound pretty good so i think i'll give them a shot. At the moment i only run Muchmore 32's. They wear pretty well and give heaps of grip on good tracks. They seem to not have enough grip on slippery tracks. Hopefully the Jaco's will give me an alternative..
Thanks Guys...keep em coming!
Jack - Have the new thicker sidewall tires been shipped? And if so anyway to tell the difference between the two? I know people are bringing their own tires to run during practice at IIC. I dont want to sell tires to people that are going to handle different than the tires used as handouts in Vegas.
Corey
Corey
