Like Tree167Likes
Tamiya XV-01
Old 01-11-2013, 01:41 AM
  #46
looks great, it seems that the shocks are a little bit longer then they mostly are. But i could be wrong.
addicted2blue is offline
Old 01-11-2013, 03:49 AM
  #47
stormridersp's Avatar
Originally Posted by kentech
Official photo of the TC kit to be released February.
58558 XV-01TC PRO Chassis Kit
The most interesting feature I can recognize from this picture is the front shocks´ angle. The XV-01 Rally version for instance have its front dampers angled almost vertically.
I´ve been thinking about this quite a lot lately, as I´m trying to figure out how to set it for on-road. The problem that I have found in the Rally version is that it´s stock suspension geometry is not very optimized. I figure that Tamiya had to compromise the overall suspension geometry optimization in order to create a cross over vehicle.
From my studies so far, I concluded that Tamiya designed the suspension geometry (for the rally and truck versions) having the TRF/CVD dampers as the starting point. Its quite obvious because it wouldn´t make sense to invent a new damper design. How would you design the suspension geometry, using the stock 55mm dampers as the starting point and at the same time, suit tires/wheels of very different sizes, ranging from 64mm to 78mm diameter? The outer suspension arms´ travel lenght is 35mm fromthe lowest to highest points, while the TRF dampers´ travel length is only 1.2mm! You must make some compromises somewhere!
So now, back to the XV-01TC, from this picture and the info provided at Tamiya´s website, its now known that it will feature the TA-06 suspension, which by itself probably means that its suspension geometry is far better optimized to use on-road than the rally version! Tho I have the Rally version, and LOVE IT, I´ll definitely also buy this compatible TA-06 items to be able to run it truthfully anywhere!
stormridersp is offline
Old 01-11-2013, 11:17 PM
  #48
Raman's Avatar
Trader Rating: 94 (100%+)
Correct, the XV-01 TC uses the same arms that come on the TRF416/416, TA05/TA06, TB03 etc.
Raman is offline
Old 01-12-2013, 06:23 AM
  #49
Interesting with the TC, I'm planing to make a carbon fiber chassi and topdeck for shorty lipo, may be change to the TC/416/TA06 arms as well that would make it a XV-01TC R
#53928 TA05/TB03/415/416 Short Reversible Sus Arm
#54031 TA05IFS/TB03/416 Carbon Reinforced F Parts (Hub Carrier 4)
#51332 TB03/416 Front Upright
#51333 TB03/416 Rear Upright
#53825 TA05/TB03/415/416 2.6mm Stainless Sus. Shaft Set
Original Pro swing shafts are 39mm rear and 42mm front, is say the TC have same lengths front and rear and in the pic rear looks aluminium but is it 42mm, 44mm or 46mm?
dark_luna is offline
Old 01-12-2013, 10:44 AM
  #50
Raman's Avatar
Darkluna, I would recommend you wait for the TC version to come out so that you don't end up buying extra parts for nothing.
Raman is offline
Old 01-12-2013, 11:35 AM
  #51
Raman, yes your right better to wait but I will cut the carbon chassi anyway.
Because whey still use the same plastic chassi on the TC there should not be any change of suspension mounts.
On the other hand when you make your own chassi you can drill holes where you like
Does someone know the width of the TA05/TA06/TRF416 suspension arms?
Old 01-14-2013, 03:21 AM
  #52
How do you cut your carbon fiber parts?
Old 01-14-2013, 03:42 PM
  #53
stormridersp: Good old hacksaw, drill and rasp
Old 01-14-2013, 03:57 PM
  #54
Raman's Avatar
Don't forget a mask and gloves carbon fibre dust is not good for us humanoids. It's so fine that it can enter our skin poors.
Raman is offline
Old 01-15-2013, 02:51 AM
  #55
Thanks dark_luna and Raman, those carbon fiber nano-tubes are very carcinogenic, specially when exposed to soft and wet tissues.
Old 01-15-2013, 12:47 PM
  #56
DangerCow's Avatar
I have a pro kit coming, with an HPI BMW M3 GT Touring Car Body (190mm). What offset wheels should I run? I believe 3mm is stock?
I asked the AMain help-person, and was given a link for 6mm wheels, didn't seem right (Average Joe's video review said he used 3mm)
DangerCow is offline
Old 01-15-2013, 01:02 PM
  #57
Raman's Avatar
It kind of depend to the HPI body. I'm running the original 1980s M3 on mine with zero offset and its fine.
Raman is offline
Old 01-15-2013, 02:59 PM
  #58
Yes mask and gloves are good to use when cutting carbon fiber
The Tamiya wheel spacer (blue #53646 and red #53646) are great, depend on the depth of the rims hex you can easily add 0.5mm, 1mm, 1,5mm, 2mm offset or more. Tamiya rims usual have deeper hex (you can add more spacers) then for example Schumacher Rev-Lite rims but you can still add some.
Old 01-16-2013, 06:49 AM
  #59
+ YouTube Video
Old 01-16-2013, 07:16 AM
  #60
+ YouTube Video
Nice video man and NICE POWDER!!!! Where is it?
