unregulated
unregulated
I am running 1500mah 2c lipo,dx3r, 2 hi-tec 7955 servos and an mpi regulator. Question is can I run w/o the regulator???????
Yes.I was told by the Hitec guy the 7xxx series servo boards can handle it.I also just saw them put it in print some where maybe neo or a mag?
Friggin toss the regulator. I am rolling the dice on my futaba 9351's unregulated. I have only been running lipo for a little over a month but I just know to many people in my region doing the same thing and not having problems. I bought a new set of 7955's if my futabas go up in smoke. From what I have read on the hitec thread the 7955's will handle an unregulated lipo.
i ran 5955's for 2 years on unregulated lipo, if your receiver can handle it..go for it
For 8 months ive been running no regulator with 2000 lipo spec rec. and jr servos 9100s and 8711! No problem yet! when i was running with reg. had more problems with reg going bad!
Can anyone in the industry or anyone that has spoken with the manufacturers say why Does the radio manufacturers not come right out and say if a regulator is needed or not. Ive seen WAY to many racers run no regulator now with no issues at all. Whats the BIG secret???
Tech's from Hitec have released statement's basically saying after significant testing they found No Ill effect's on the 7955 when running UN Regulated....i know this probably wasn't the smartest idea a month or 2 before the release of the Actual branded High voltage servo's...but the proof is in the pudding.....How many Respectable Knowledgeable guys on here are TELLING YOU its fine to run them without a regulator...and even if something does go wrong.....They WILL warranty it no question's asked.
They will replace the servos but what about the engine that blew from being WOT on a runaway or your broken buggy from hitting a wall at WOT?
That being said I am running 5955TG with Spektrum receiver in my 3PK and will not be using a regulator, seen too many problems with and so far no problems without!
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Throttle return spring. It isn't just to pass tech at big races.
