Gearing the Novak 17.5 compared to a CO27 >
Old 11-16-2007, 09:46 AM
Default Gearing the Novak 17.5 compared to a CO27
Well were going to go up for the Novak race and my son will run in the sportman class with the 17.5.
Couple of questions about the 17.5 gearing:
1) Do I gear about the same as I do for a starting point brushed and brushless?
2) Once I use the gearing as a starting point. Do I use the temp gun to try and obtain about 170 deg motor temp as I am with the 13.5?
The track is about 90 x 48 in size indoor carpet.
Thanks..
bigdog xxx-s is offline
Old 11-16-2007, 10:13 AM
Essnowyt's Avatar
Sup Big Dog!
Rodger at Trackside did a lot of testing with a 17.5. He found that he had to gear the motor STUIP tall. Much taller than our 13.5. So i would somewhere around a 4.0 ratio.
Hope that helps.
Essnowyt is offline
Old 11-16-2007, 10:36 AM
Trader Rating: 3 (80%+)
I believe there will be a limit on the gear ratio at the Novak race for sportsman class............I don't think it has been determined yet but I will try and find out and get it posted soon
also keep an eye on Trackside.com for rule updates
Josh Hohnstein is offline
Old 11-16-2007, 10:38 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by Essnowyt
Sup Big Dog!
Hope that helps.
4.0 ? I run a 3.96FDR on my 13.5 now
Marcos.J is offline
Old 11-16-2007, 10:43 AM
Your parents must be proud
Old 11-16-2007, 10:44 AM
Super Moderator
Marcos.J's Avatar
they are !!how did you know??
Marcos.J is offline
Old 11-16-2007, 11:51 AM
Sup Big Dog!
Hope that helps.
Thanks guys...
See you boys in just over a month...
Old 11-16-2007, 03:29 PM
sportpak's Avatar
Trader Rating: 26 (100%+)
In my 12th scale I ran it at a 2.95 rollout. It made it near impossible to keep it rolled out as the tires got smaller. In my rubber tire/carpet TC, I run it at around 4.2 final drive. I can go lower and will be soon. It's a great "stock" motor. Finding the room to roll it out is a pain. Welcome to the land of big pinions/small spurs.
sportpak is offline
Old 11-16-2007, 04:48 PM
Smile
For 1/12th run something over 3.00. More in the range of 3.18. I have no problem staying with the co27's. Sportpak needs to try harder. You need a 78 spur. You will not be disappointed unless you race sedan then everything is disappointing.
cookie1 is offline
Old 11-16-2007, 05:52 PM
Doodad's Avatar
Ouch, babe...Very ouch!
Doodad is offline
Old 11-17-2007, 04:44 AM
Essnowyt's Avatar
Originally Posted by sportpak
In my 12th scale...
For 1/12th run...
He is not asking about 1/12 scale ladies! Why even bother with a 17.5 in 1/12 scale?
Snowy.
Essnowyt is offline
Old 11-17-2007, 12:43 PM
Kings Kid's Avatar
Trader Rating: 35 (100%+)
Snowy.
well,he's not asking but alot of people are going to want to know.Our local track last year allowed me to test the 13.5 in 1/12th and decided it was too fast for the stock motors in the class. This year the allow 17.5 in 1/12th. According to CRC (my conversation with John) Franks gearing with the 17.5 was 43-76. I'm geared at 42-92 (which worked well last year for the 13.5) and it ain't fast enough.
Kings Kid is offline
