GT class--buggy-based on road!
#1786
AFM and rest of the crew,
Well, i joined the big boys and today i raced first time my OFNA DM-ONE, the format its simple, 3 x 5 minutes qualifying, lower 10 minutes mains and A-Final 25 minutes.
I qualyfied very bad being my first time with the car and bumped up to the A-Main, ended 3rd so im very very happy.
This cars are a lot fun to drive and very very fast, i used my GO Engines .21 5 ports + EFRA 0801 GO pipe ... 9 minutes and 50 seconds runtime very good ...
cya and thanks for all, next race again in 3 weeks
bye,
bye,
#1787
#1788
#1790
If you're running the aluminum 2 shoe clutch, it tends to mushroom just like a 3 shoe except over the spring and cuts away at it. If you switch it out to the KC45 carbon unit and you'll have no more problems.
#1793
Guest
Someone has done it!
I read somewhere it has been done, but it did require some mods to the chassis. Werks makes a centax type clutch for offroad buggies that would probably work with no mods.
#1795
Regards,
Speyederjedi
#1796
I'm using the stock 3 shoe clutch, but I'd like something that would allow the engine to spool up to a higher RPM before engaging. I've seen a couple of races of this class and I'd have to say that the biggest drawback to these kits are the clutches. The clutches engage too early and due to the weight of the car it takes them to long to get up to speed,but that's just my opinion. I think an adjustable centax type clutch would make a big difference in performance.
Regards,
Speyederjedi
Regards,
Speyederjedi
I felt what you say but only on the first qualy when i used 0.9mm springs, with 1.1 the problem was solved,
#1797
Too hitec IMO. These cars are meant to be simple. In Inferno shorten the length of the spring, get a stronger one and/or enlighten the shoes if needed.
#1798
Regards,
Speyederjedi
#1799
I guess we would have to agree to disagree. I feel that in any kind of racing you want to maximize the power offered from your engine. If your clutch is engaging before the engine is operating in it's power band then you're at a disadvantage even if every other racer is in the same situation. Besides, centax clutches are not that complicated and are easy to adjust. If you ask me, pulling a motor to change out your shoes or springs is much more difficult of an adjustment than holding a spring nut in place and turning the flywheel without having to pull the engine out of the car. Running a centax clutch would actually be easier. IMO.
Regards,
Speyederjedi
Regards,
Speyederjedi
#1800
I think what MikaR is trying to explain is that the concept of the GT class racing is to try to lower the overall costs associated with on-road racing, to adapt to the current world wide economic situation and to offer RC racers an opportunity to compete in a more level playing field.
There has been way too many heated debates on this thread & other threads about “Spec vs. Open” GT car racing.
There’s no debating that an “Open” GT car would produce superior speeds & lap times, but the true issue we fellow RC racers should consider with this new breed of on-road racing, are the growth and future of our sport.
My personal opinion are that these GT cars is: they are fun, very durable, spectator friendly, accessible and moderately priced; in comparison to Sedan & true 1/8 scale vehicles.
GT cars are a great “stepping stone” for newer racers into the higher ranks, a class for experienced racers that wish to compete with a more simple chassis design and for any racer that wish to be able to continue to enjoy the RC racing experience during this challenging financial climate.
Nitro Sedans & 1/8 scale cars do offer racers with the ultimate in speed & complexity, so there is really not much need for the GT cars to escalate to that level, since those types of classes already exist.
Mexico has the best example of what can be done with the GT class. They have a huge number of Spec racers attending their events. The rules are set in stone, they are having fun and there is little “in-fighting” between the people that would otherwise be good friends.
If “the proof is in the pudding” the Mexico GT class is a shining example of what does work very well.
Be it “brand” specific or not, “they’ve got it going on”, while here in America and elsewhere around the world, we’re just spinning our GT car wheels.
