sorex 28R , 32R tyre
hi i have some sorex 28R and 32R tyres and my first pack of 28 when i tried it it didnt have that much grip . I use lrp aditive and every time i accelerate it makes a funny noise like if two gears didnt mesch propelly . Everything does mesh propelly i know because i cheked many times , and i really think its the tyre because as i said it makes a funny noise and not only that but when i go very fast and i try to turn trought chicanes , i steer just a bit and the car spins but when i see the people at my local track it works fine for them and i have asked them what was my probleme they didnt know what was wrong .
And also i dont true them with a tyre truer when i open the pack , there is always a small line in the center that means the rubber is new thats normall should i by a tyre truer to true them , and will it solve my probleme .
Thanks for letting me know.
Its not necessary to true them. If you are running outside they will like remove the ridge in a couple laps. Have you tried a different set of tires with positive results? It certainly doesnt sound like the tires are the problem.
If it spins easily then it sounds like something like the diff screw might be broken or you are running 3 wheel drive (one of the cvd's has broken). Is a CVD pin coming out and rubbing on the hub?
i will try to tighten the diff but how do you tighten it , very tight or just at the limit between the noise and very tight ?
Yes but once the noise probleme is gone why does the car spins , it doesnt spin like a tornado but the rear end gets loose and i lose controle of the rear but as i can see at my local track when they go trought chicane there car is very direct and very fast and they dont lose control ?
nope i hade the noise probleme first and then the spining probleme.
I aprecciate your help thanks
i forgot to ask this how many runs can the tyre last long . when people say around 10 run does it mean 10 races of 5 minutes?
and nothing about tyres i have a ho bodies cyclone moor speed with a spool and when i corner i would like to corner faster whatcan i improve for it to corner faster
# of runs depends on a lot of things. Smoothness of the track, smoothness of your driving, heat of the track, complexity of the track, your setup, what speed motor you are running, etc, etc. Ive found sorex tires to not last as long as other tires in less then ideal conditions. It sounds to me like you are just getting started and aren't the fastest guy. In that case I would run them until they wear through. You wont be the fastest but you likely aren't even with new tires (no offense, 90% of us fall into that category).
It sounds like you need to work on the setup of your car. If someone else's car is easy to drive and yours isnt then its likely your setup. You might have too much steering which is whipping the end of your car around. Find one of the helpful fast guys at your track and they should be able to watch you drive and suggest changes that will help.
