Easiest way to clean baked dirt off of exhaust?
How do you guys clean the exhaust pipes? my pipe has some dirt baked on it. Simple green and de natured alchohol isn't doing the trick. Any ideas??
like put it on the stove and boil? is that safe?
crock pot and antifreeze
white vinegar and bi-carb soda.
take that biatch off and put her on the buffing wheel i have people asking "is that a new exhaust?''
the easiest way to get it off without going through all this boiling stuff is to get a sos pad and soak it and rub it on the pipe. takes everything off and leaves a great polish shine
Grab a bowl. Add about 7 table spoons of bi-carb soda. Then add vinegar. It will start to bubble. Soak the pipe in there for about 5 minutes. Grab a tooth brush and rub of all the baked on grime/oil and dirt.
I've tried everything and my wife recommended this to me last week to clean my EFRA 2035 pipe. Comes up great.
cheers
cheers
Scotch brite and simple green
Then buff it with polishing compound. Like mentioned above. it makes it look like new again,
Oven cleaner works great just spray it on and let it sit for a couple of minutes and wipe it off
