Advance R/C Car R10 2015 >
Old 09-27-2014, 11:01 PM
  #271
Question regarding the blitz bodies. Is it true that it already has dimples made for the r10 body post positions ?
inpuressa is offline
Old 09-27-2014, 11:19 PM
  #272
Yes holes and body lines are pretty much rtr.
Carnage9270 is offline
Old 09-27-2014, 11:21 PM
  #273
Thanks! Any suggestion for body type on a technical asphalt track for 17.5?
Old 09-27-2014, 11:36 PM
  #274
Gridworks Racing's Avatar
GSF
Gridworks Racing is offline
Old 09-28-2014, 07:55 PM
  #275
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Originally Posted by Gridworks Racing
GSF
+1
Josh-n-ya is offline
Old 09-28-2014, 08:30 PM
  #276
What is the part # of the hpi silver springs? And is are they softer than stock set up
nene_805 is offline
Old 09-28-2014, 08:32 PM
  #277
Trader Rating: 15 (100%+)
Dunno the part number for the hpi springs but they are definitely a harder spring rate than the kit 2015 springs.
trigger is offline
Old 09-28-2014, 08:36 PM
  #278
They recommended the silver springs to me. What would be a softer sprong that will work?
nene_805 is offline
Old 09-28-2014, 08:37 PM
  #279
The yokomo springs I am hearing are working well. waiting for a local shop to get the order in.
dragonracing is offline
Old 09-28-2014, 08:40 PM
  #280
HPI Silvers are not the ultimate spring. It is just what people default to as that is what they see on the pro's cars.
Depending on the level of the grip you may not want such a hard spring.
Back to back on my low grip track, the kit springs felt nicer, had a better lap time and was nicer on tires than HPI Silver.
Besercoe is offline
Old 09-28-2014, 08:43 PM
  #281
Oh ok. Thanks. Its a med. Grip track so i need something softer.
nene_805 is offline
Old 09-28-2014, 08:46 PM
  #282
What handling attributes are you trying to achieve?
Besercoe is offline
  #283
Ive had good results using arc blue(either version 1 or 2015 blue) on med traction tracks.
trigger is offline
Old 09-28-2014, 08:50 PM
  #284
Well, the car feels really good, but their was a famous pro guy at my local track today
that told me i need softer springs.
nene_805 is offline
Old 09-28-2014, 08:55 PM
  #285
Dont forget that geometry plays a big role in what springs are required.
Are you using the correct kit positions on the arms? Front on the tab side outer, rear on the non tab side outer position. This with the kit springs especially on the rear is quite soft already.
Make sure you have built the car to kit settings, nearly every 2015 kit i have seen people build has the rear arms in the wrong shock position
Like i said above, most people will just look at pics of Volker's Yokomo or Reinhard's Tammy with HPI Silver springs and say that's what they need to run, without actually trying other options. We dont all race on prepared tracks.
Besercoe is offline
