HB Racing D819 Nitro Buggy
HB204439 HB RACING Diff Input Gear (13-43/Light)
HB204440 HB RACING Input Gear Shim Set (8pcs)
HB204441 HB RACING Dogbone 85mm
HB204442 HB RACING Dogbone 118mm
HB204443 HB RACING Transmission Conversion Kit (D817)
HB204444 HB RACING Front Sway Bar Set V2 (2.3, 2.5mm)
HB204445 HB RACING Rear Sway Bar Set V2 (2.5, 2.7mm)
HB204450 HB RACING D819 1/8 Competition Nitro Buggy
HB204451 HB RACING D819 Decal
HB204456 HB RACING D819 Swaybar Pivot Ball v2 set
HB204458 HB RACING D819 1-pc Swaybar Link (2pcs)
HB204459 HB RACING M2.5 x 12.4mm Pin (4pcs)
HB204461 HB RACING One Piece Engine Mount (D819)
HB204463 HB RACING D819 Hub Carrier Arm v2 no.3 (4pcs)
HB204464 HB RACING D819 Hub Carrier Arm v2 no.4 (4pcs)
HB204465 HB RACING D819 Hub Carrier Arm v2 no.5 (4pcs)
HB204466 HB RACING Engine Mount Adjuster no.1 (4pcs)
HB204468 HB RACING Engine Mount Adjuster no.3 (4pcs)
HB204470 HB RACING S15 Buggy Bodyshell Standard (HB Racing D819 - JConcept)
HB204471 HB RACING S15 Buggy Bodyshell Lightweight (HB Racing D819 - JConcept)
HB204472 HB RACING HB Megabite Mounted Tire (Yellow Compound/White Wheel/1:8 Buggy)
HB204476 HB RACING Arm Mount 2-dot (B/+0.7mm)
HB204478 HB RACING Lightweight Wheel Hex Hub 2pcs (Narrow)
HB204479 HB RACING Brass Wheel Hex Hub 2pcs (Narrow)
Thank you for your
It appears to be the same car again. Very minor changes.
not liking the gearbox change, I liked the dogbone going into the pinion. box art shows the normal style drive cup.
agree and also they didn’t go for the wider C & D blocks and the short arms like the ones they were using at the worlds .
I like it as well, but I would like to see something change about the shims. It seems like every time I pull my pinion out, there is some sort of shim damage. Maybe whatever change they make will correct this.
looks like it doesnt come with front springs? hahah
I haven't damaged a shim yet, but did forget about them and was confused on why I couldn't get the damn gear out. once I removed them it came right out. Surprisingly my bearings are still the original ones on the pinion gears, on both my e and d817, both are first shipment buggies. I just love the fact that there are no set screws on the drive train, easily the most dependable setup on the market.
