Serpent 720
#3872
DJ
#3874
Hi Guys, i had my first run with the 720 yesterday. with a 4 tank testing session on saturday, and 17mins of racing on sunday, i am already matching times i did with my G4RS. my car is a first model 720, with the one piece engine mount. i have a spool in it. i am waiting on the WC gears so i couldnt use the gearing i wanted to , and the std chassis.
are any of the new parts for the 08 that can give the car a better edge than im currently using.
i did DNF due to battery problems. i suspect fuel shorted my lipo, as the balance leads were dripping of fuel, and i had a run away while 1.5 seconds behind the leader. so a promising start i would have to say. cheers.
#3875
I cut under the upper bumper plate with an knife. I cut to the size of the weights I am going to use. Then I cut from the back side of the bumper across so I can pull out the foam piece I cut from the top. Then I use some kind of glue and put in the weight. I usually put the weight as low as possible and mount some of the foam on the top of the weight. When it is done sometimes you can see my weights. Hope this helps.
DJ Apolaro
DJ Apolaro
#3877
#3878
#3879
#3880
try http://www.kamikazercracing.com/ Sam has all kinds of serpent stuff,if u dont see it on website call him directly.I bug him all the time.
#3885
