Team Corally RDX Touring Car
#8536
Oh, I just noticed that the bladders that came in a new kit seemed much stiffer than the bladders I got in my kit, and even those I bought as replacements a while back. I'm just wondering if maybe Corally changed the compound recently, they tend to quietly sneak little changes in there sometimes.
#8537
Anyone has some advice for a newb to RDX as far as what to look for and ask about when looking at picking up a used RDX? What sould I expect to pay for a roller chassis?
#8538
advise when you will buy a kit and you feel you need to clean the diff!! when you rebuilt it dont overtigth the screw cause it will brake and you will need to buy a new piece of diff for your car!! also if the car dont have the front SRC bumper buy it!! it will help the car to dont brake and it will save you some arm and money ehhe!!!
#8539
Thanks for the info on the diff.
Is there anything on the car that is particularily prone to wear or breaks? I just don't want to get caught paying like $250 for a car and then having to spend a bunch on it to make it race ready to the point I should've just bought a new kit in the first place.
Also, where are you guys getting your parts from? I would have to mail order my stuff since the local hobby shop doesn't support this car. I checked on stormerhobbies.com and they didn't list a bunch of the misc screws, and the shock rebuild stuff
#8540
Anyone had bent or out of shape diff output shafts? Bought all new pieces for my diff except those and built them up nicely and it seems to be catching at a certain point in the turn. Built two brand new diffs last week for my other car and they are perfect. Cant figure out the problem with this one except that it seems one or both of the halves might be out of shape?
#8541
Are the new lowered shock towers meant for carpet, asphalt or both?
Are they currently being shipped in the carpet kits?
#8542
or8ital-
check the c-clip in the diff halve that holds the thrust washers. If it got bent during a rebuild it will catch and make a tight spot.
#8543
#8545
Originally Posted by barnacle
or8ital-
Using the associated grease and lube...
#8546
-Korey
#8547
Originally Posted by shaggster
Just wondering if anyone has tried the lowered shock towers on both the front and rear of the cars for the same suspension geometry w/ the cut off shock shafts?
Thanx,
Shaggy
Thanx,
Shaggy
-Korey
#8548
Originally Posted by or8ital
Im lost on this. I bought the new diff halves and it didnt fix my problem. Thinking it might be the c-clip I built the diff as the long half comes (with the thrust installed) and it still seemed "notchy". Tried rebuilding again and still feels notchy. Everything is brand new. Ugh....
-Korey
#8549
You can buy snap rings in bulk, on the cheap from X-Ray.
#8550
Thanx,
Shaggy
Thanx,
Shaggy
I think the lowered tower in the rear would rub the belt.
