Serpent 710
Originally posted by InitialD
You mean the ones that you use to "shim" for the steering servo? I forgot what I used... I guess you just use it so that the steering servo arm aligns nicely along it's movements...
Re: Re: Re: Re: Re: Re: Pyramid
Originally posted by Pyramid
Your partner said they lowered the top deck by 3mm.
Now all Mega Power Pack has come in a better packaging that gives more value to customer. As promised, the glow plug is now included.
Front view of the bag
Damn.
I hate it when you buy somthing when it first comes out, only for it to be offered in a better package deal less than a month after you got it, and for little or no extra cost....
I know how you felt, I buy my own gears too.. not just received them for free..
On the other hand, look at it this way,
It is very hard being a manufacturer.. things you decide to give for free later on.. you get complain.. things that should have been free but you trying to sell it.. you also got complain. Clear example of either you did or did not, still go to jail.
Visits the team xray forum on FK05.. there are soo many customer wanted to be heard and wanted to be satisfied to their own personall current needs.
Cheers, Mark.
Originally posted by sparksy
Damn.
Damn.
I'm still thinking about the Mega and the new Hudy setup - but no definate plans to buy either at the moment, although my local supplier now offers the Hudy full setup kit for only €240
Cheers, Mark
Originally posted by markp27
You getting one? Was there any news about if the current kit is upgradeable? Probably not, I assume.
Cheers, Mark.
Cheers, Mark.
see here for new part number,
http://www.world-model.com/newproduct.html
swooooossh!!
Upgradable, but costly..
It would be easier to justify upgrading to the FK05 if the 3mm was already included, but now if I keep the FK or buy the FK05, I need a 3mm chassis - looks like the FK04 will be staying.
clutch shims
Does anyone know the partnumber of the shims,
marked with the red ?
They are used between the centax clutchnut and the ball bearing to avoid "clutch dragging". I do have other shims at home, but the outer diamter is too big and they wrub against the bearing.
I cannot find an ordernumber. It really doesn't have to be "original" shims...
thx,
Maarten
thx,
Maarten
Re: clutch shims
thx,
Maarten
thx,
Maarten
http://www.the-border.com/product.ph...1&cat=0&page=1
Cheers, Mark.
Re: clutch shims
My LHS sells the correct size (5 x 7 mm if I'm not mistaken) Kyosho shim set. It comes in 0.1, 0.2 and 0.3 mm sizes.
Part number is 96643.
Re: Re: clutch shims
