Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 01-28-2018, 05:07 PM
  #3781
JRSlash's Avatar
I have the 0 degree offset hubs on my car along with the 66.5mm axles. Is possible to use the schelle or MIP 67mm lightweight axles for this car? .5mm doesn’t sound like much but would like to know if anyone have tried.
JRSlash is offline
Old 01-28-2018, 08:07 PM
  #3782
Pekr.da.skurl's Avatar
Trader Rating: 12 (100%+)
Ok who here runs a 4 gear transmission, on what surface and what kind of weigh you run? Thanks
Pekr.da.skurl is offline
Old 01-29-2018, 04:42 AM
  #3783
Trader Rating: 65 (100%+)
I ran a 4 gear on the original YZ2 with brass rear front suspension block and brass rear ballstud mount. Plus brass front bulkhead mount and shorty all the way back. Car was good on high bite clay. I ran it a few times on low bite dirt and it was ok but not as much grip as something like a standup rear gearbox.
Pekr.da.skurl likes this.
Antimullet is offline
Old 01-29-2018, 05:21 AM
  #3784
I'm running on medium traction dirt/ clay mixture. Just wondering what it would be like so Sunday I ran with a 4 gear trans. I't was hard to drive but I can get faster lap times with it.
Old 01-29-2018, 06:16 AM
  #3785
draboyd19's Avatar
Trader Rating: 30 (100%+)
I know the Schelle 67's are drop in with offset hubs....MIP stuff should be fine as well. I know the TLR bones fit in the Yokomo axles, but I'm not 100% sure about B6 ones, so might try the TLR 22 MIP/Schelle stuff.
JRSlash and davinco like this.
draboyd19 is offline
Old 01-30-2018, 05:20 AM
  #3786
JRSlash's Avatar
Thanks, Ill be trying the Schelle 67mm shafts. I don't think .5mm will be that much of an issue....
JRSlash is offline
Old 01-30-2018, 05:50 AM
  #3787
draboyd19's Avatar
It's not an issue....I run the TLR Spec racer driveline in my stocker, and they have 67mm dogbones.
JRSlash likes this.
Old 01-30-2018, 03:16 PM
  #3788
Arctic RC's Avatar
Quick question!
Does the wc car come with alu front upper arm mount?
Arctic RC is offline
Old 01-30-2018, 05:07 PM
  #3789
draboyd19's Avatar
Originally Posted by Arctic RC
Quick question!
It does not come with an alloy from camber link mount or front bulkhead...does include alloy bulkhead braces though.
Old 01-30-2018, 07:56 PM
  #3790
Trader Rating: 90 (100%+)
Quick question!
Found this on petitrc. Shows all the wc upgrades http://site.petitrc.com/setup/yokomo...anualAddon.pdf
b121774 is offline
Old 01-31-2018, 02:11 AM
  #3791
my YZ2
smrcboy is offline
Old 01-31-2018, 06:18 PM
  #3792
PorTX's Avatar
Anyone happen to know what changes might be coming in the next YZ2? Still going to be a CA and DTM car? Looking to buy a new Yokomo but nothing available anywhere. I run on mainly black CRC carpet and attend a few races on a high bite indoor clay track. So I want to make sure to get something more suited for those.
PorTX is offline
Old 01-31-2018, 08:43 PM
  #3793
MarkA's Avatar
Trader Rating: 21 (100%+)
I've used and sometimes still use it on low grip, slick astro. Run it lighter than you would the 3gear. Doing so helps with the fore/aft yaw the 4gear cars has. I don't go over a total car weight of 1540-1550g running mod with it like that. My high-grip car is sometimes north of 1600g for comparison.
MarkA is offline
Old 01-31-2018, 09:42 PM
  #3794
Cain's Avatar
Trader Rating: 294 (100%+)
alright did some assembly work here, will see how it goes for this coming race but I got the CA style rear upper mount assembly (the one with the holes all straight across) that has the weights you can add to it sitting here NIB, I was thinking of giving it a go versus the DTM style one. For current carpet setups is that one worth looking at or should I just get the DTM one in alloy?
Cain is offline
Old 01-31-2018, 11:00 PM
  #3795
yes, ca2 and dtm2 around march. what will be in the package hard to tell, for sure some bits from worlds car (steering, rf or rr mount, etc) and new battery holding brace, different type. guess something like b6.
dabear is offline
