RX Liporun times
#16
as an example to the length of the lipo tho. he went a full race day, two 6 min qualifers, 10 min main and bumped to a, then a 15 min main. I forgot to switch his battery off and it was on ALL week long until friday(he raced the sat b4 that) and noticed it was on. he poped it on the charger expecting to be buying a new lipo. it was dead but just over 3v per cell. i was suprised
that pack is hurt...i would be surprised if it didn't give you issues.
On a side note ive had issues with my losi 2000 rx pack....granted its over a year old and seen probably 150+ cycles but it started to glitch out one practice night multiple time's back to back...so i immediately brought it in and swapped the losi out for one of my 900mah practice packs....3 tanks back to back and no more issue's...so my losi 2000 is now sitting on the shelf and i stocked up on 6 more 900's....45 min on 900 isnt a problem....but a full hour might be close.
#17
well then i figure i have another 90 cycles to reach 150 lol. when i went lipo you told me to keep a log and i have up until about the 20th cycle. my losi is consistant day in day out. the only couple issues iv had were it not fitting in battery box easy. the bottom of the losi box has that screw hole coming up through the bottom. anyhow it pushed a little dimple into the pack. no probs with it though. anyhow iv always used the tall covers and stacked it with foam below and above
#18
as long as each cell is at least 3v, the pack is fine. Most lipo cells can actually go down to around 2.75v per cell without damage. And all lipo cutoffs are set for 3v per cell....(6v total on a 2s, etc.)
#19
back to back testing proved otherwise on the losi pack....and imo lipo's will not go below 3.0 without damage...they puff up and can lead to failure if you continue to use it.
#21
I would keep 2 on hand in case there's a bump situation or something like that arises.
after all they are a little under 6$ a pack shipped.
#22
The pack did get warm to the touch but it didn't puff up or swell. I threw on the charger to balance it after it cooled down. It did go up to 8.4v but I'm still worried it gonna dump on me.
#23
I'm not worried about any warranty's as these are well out of warranty anyway by a mile and have had no problems the whole time. I'm sure there are some out there that burn up with any brand since there are very few servos that are actually rated for anything over 6 volts. But I've seen huge problems with people running all different brands of regulators, I definitely won't go that route.
JR has an excellent 3 yr warranty, the 9100 series was released about 18 months ago. So by my calculation that's about 18 months left of warranty if you bought them the day they were released. Not worth risking a $140 servo for lack of a $20 regulator.
#26
Ok well i just ordered the losi lipo pack, its on bo so ill let yall know if i like it after tryin it out.......
#27
Dose anybody know if these packs are just re-badged losi packs?
http://www.dynamiterc.com/Products/D...ProdID=DYN1419
#28
sitting side by side they sure look like it dont they....
#29
i would say its safe to say so.
#30
I think I will now do the same and keep my lipo above 3.5v/cell always, I use to bring it down to 3.3v but, I have a feeling sony erricson guys know a bit more about batteries.
voltage was measured using fluke DMM.
