Losi 1/8 8ight E 4wd Thread
#3571
If this is really a problem then the way to fix it, is to go to a smaller hole piston in the shock. This increases the pack and help minimize this effect. Going up in shock oil helps to a point but a smaller hole piston will have a more dramatic effect. Springs don't help a lot in this regard either although your springs make have "worn out" and need replacing.
#3573
I've had a pair of the silver front springs sag out to the point you couildn't get the correct ride height with an "e" conversion. IMO the silver springs in the front just don't cut it with any "e" conversion. I took some careful weights of both a nitro 8ight and my electric 8ight and found the "e" car to be about 7% heavier in the front than the nitro with a 1/2 filled tank. If you do the math on the springs you find they are about a 6-7% change per rate. So, going to a green in the front makes a lot of sense.
For reference my 8ight uses the the losi conversion with a Tekin system and a 500 gm 4900 4S soft pack. If you are using a bigger pack or a hard pack then you will be even heavier than my car.
#3574
my silver's up front and just dandy.....but then again my car is Far from being a Stock E.
#3576
#3577
Nice! I like the tower comparison. Did you change anything in the drive line?
#3578
not yet....i have mugen bones waiting to go on for the center shaft's but im running out the stock losi bones i have still....with a pin pressing tool you can make the bones last A Lot longer.
i also run the plastic spur....imo there's no need for a steel spur.
#3579
i need help??
Hi guys I am wanting to go electric on my buggy, I want to know what combos of motor an speed controls work and batteries work. Please?
#3581
i need help??
#3583
Tekin 1900 on 4S 5000's is what i run...but there's soo many variables to decide you really have to do some research and make a decision.
#3584
[QUOTE=Integra;6970981]Tekin 1900 on 4S 500e0's is what i run...but there's soo many variables to decide you reially have to do some research and make a decision. [/QUgraOTE]
Integra.I only know u from RC tech. And seem to be a good racer, I will go with tekin. What Coversion would you use for with the 2.0 buggy. And pinions I looked on eBay an could not find any. Any help is good. I like gas but I never have a steady pit crew, and that sucks for me. That's why I want to try electric.
#3585
Hey guys, what are you running for diff oil on a tight,hard packed, greasy indoor track? I run 5-7-2 for fluffy outdoor now. I was thinking maybe 3-5-1Thanks for any help...
