Team Corally RDX Touring Car
#3121
Does anyone make a rear body mount plate that will let me fit a mazda 6 shell?
Also what do people do when running the front roll bar as mine hits the steering blocks when the steering is turned and the suspension compressed.
#3122
Team EAM
Rick,
I take and move the rear body mounts all the way in where the slots are on that plate. You will need to take a 1/8 inch drill bit and open the slot up just a tick. But it wont hurt it. I havent seen anyone break a body mount plate once moved in either.
On the way bar I would say you have the front mount on back wards. Im looking at my car and it wont even get close untill you move the tire up about and bottom the shock all the way out. It wont move that much during a race.
EA
EA
#3123
1.how mm of downtravel people used normally for carpet??
2.do you want more down travel for the rubber??
3.2mm in the front and 2.5m in the back its is a good starting point?
Later!!
Later!!
#3124
Bearings for one piece spur gears
I just got one of the one piece spur gears (part# 79310) but when I went to fit it I discovered that the bearings that came with my current black spur gear do not fit - they are too small.
I drive a UK spec kit - is this right or am I just being stupid?? Do I need to put in bigger bearings and does anyone know the size I need?
Cheers,
Stephen
Cheers,
Stephen
#3125
It has come!!! it looks like such a nice kit and i can't wait to start building it and even better racing it
#3126
I have a bit of a problem with the RDX. I am putting together the Diff and for some reason it isnt working. I think i have not been given the diff pully but insted two of these?
Am i just stupid and its in another bag or i am actually missing something.
#3127
Those are the one piece pulleies. They should work I have them and have been using them for about 6 moths now with no problems.
#3128
Well im so totally because how do i set it up because the manual is telling me diffrent to what i have got in the bags. ALSO i have found no bag 2 in there
#3129
It is pretty simple. Instead of screwing the diff pulley onto the other diff half it is now a ONE PIECE PULLEY. So skip that part and move on to normal diff assembly. Simply put in the diff balls and follow the steps for the washers and assemble.
The kits are getting "running changes" which take the overall value even higher at no additional cost to you and it is tough to keep up on the manuals as you usually get 100's printed at a time. Sorry for any confusion.
Jeff
#3130
Thanks i now understand and every thing is running real smooth for now
#3131
RDX and Helger UK
Hello,
If you are in Bristol Uk, phone Helger racing they will help you immediately. Andy
#3132
Thanks andy ive sorted it tho any ways
#3133
Hey Jeff, instead of printing new manuals, maybe additions or updates could be added to the kits...they can just be a simple half sheet of paper stating the updates in the kit thats different from the manual.
#3135
Originally Posted by andyuk99
Hello,
