MRX-4X
Old 08-02-2008, 10:39 AM
  #436
http://www.kamikazetoysandhobbies.com/home.htm
nitrodude is offline
Old 08-02-2008, 11:09 AM
  #437
Originally Posted by nitrodude
I second that great family to talk too
motojon is offline
Old 08-02-2008, 03:59 PM
  #438
PROVK's Avatar
Trader Rating: 14 (100%+)
Originally Posted by scott74dog
Do people put grease on the dogbones. I can only get 2 races and the solid axle and dog bones get pretty wore out. I didn't know if I put lube on them they would last longer or am I making it worse.
Also does anyone have recommendations on a cheap online store, since none of my local hobby shops carry mugen parts.
Scott
Scott
Always use a suitable grease!!
Either Mugen grease or Tamiya Moly
PROVK is offline
Old 08-02-2008, 04:49 PM
  #439
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Hey guys I am Trying trying to find more steering entering a turn off throttle.I just performed the wheelbase modification yesterday.My settings are in the attachment.Look in the notes section for handling aspects.Thanks for the help.
sm1nts2escape is offline
Old 08-02-2008, 04:56 PM
  #440
I could not attach it.Here it is
Old 08-02-2008, 06:03 PM
  #441
sohlman's Avatar
Trader Rating: 92 (100%+)
Are you running the front lower arms forward (3mm spacer behind arm) and the upper arms back (3mm spacer plus 2mm caster spacer)? That's too much caster. The 3mm spacers need to match on the upper and lower arms...either forward or back. Then adjust with the 2 or 1mm spacers. And I assume you are running 2 degrees of negative camber...it just says 2 degrees. Same with rear.
Try these in order:
lower arms back (3mm spacer in front of the arms)
35 fronts with 37 rears
Add front camber
sohlman is offline
Old 08-02-2008, 07:21 PM
  #442
wingracer's Avatar
Trader Rating: 24 (100%+)
I've been fighting much the same problem at 301. Here are a few things to try.
1. Move the front shocks to the lowest hole on the tower.
2. Use the X eccentrics.
3. Try going back to the 5mm rear lower arm mounts or even go to the 5.5 (what I am currently running).
4. Red rear springs.
wingracer is offline
Old 08-02-2008, 08:12 PM
  #443
Yeah I am running the front upper arms spaced 2mm forward and the lower fronts spaced 3mm forward.
Old 08-03-2008, 09:47 AM
  #444
quietstorm76's Avatar
Trader Rating: 12 (100%+)
I've found that the 5.5 will give greater steering. I use to run the 4.5 and the car always pushed no matter what.
quietstorm76 is offline
Old 08-12-2008, 01:12 AM
  #445
Hi there!
Has somebody found a way to disengage the front sway bar on the MRX quickly? When I adjust downstop, I would like to disengage the bar because one arm will not drop completely against its stop. With Serpent cars you can just slide the sway bar to the side. Any tricks here? Same goes for adjusting tweak on the Hudy system. Normally I test first without bars, but with the MRX I have yet to find a way to do this...
Many thanks and regards
Stefan
fulcrum2 is offline
Old 08-12-2008, 04:41 AM
  #446
getpip's Avatar
Hey guys .. can anyone answer this question for me...
How much cone do people cut into a new pair of rear tyres?
getpip is offline
Old 08-12-2008, 06:17 AM
  #447
YBSLOW's Avatar
1 to 1 1/2 degrees
YBSLOW is offline
Old 08-12-2008, 06:33 AM
  #448
sm1nts2escape
Ranson,WV
68 Posts Since Jul 2006
Trader Rating: 0
08-03-2008, 07:49 AM
Report | Post #439
What is the wheelbase mod?
Smarty is offline
Old 08-12-2008, 06:46 AM
  #449
sohlman's Avatar
The wheelbase mod is a hand modification to the rear arms. See post #963 on the MRX4R thread. Link below.
http://www.rctech.net/forum/nitro-ro...mrx-4r-33.html
There are a few things to add:
1. Most remove a little material from the lower rear arm by the "up screw" holes to preventing binding against bulkhead
2. Works best with the 4.5 blocks (5.0 and 5.5 need too much material removed from them, weakens arm)
sohlman is offline
Old 08-12-2008, 01:28 PM
  #450
I cut my arms to fit 5.5 blocks and it does require a little bit of material to be taken off but they are holding up good so far and I am no wheres near a perfect driver.I think you will be cutting yourself short if you are already running 5 or 5.5 blocks because the 4.5's push the car alot.
