Team Magic G4
#6706
There's no mention of the packs on the site?? I hope they are available now.
Menace
Menace
#6707
Originally Posted by cheesewhip
I tried that but it wouldn't stay put. It also did come real close to the side belt.. and with me using it for racing... one tap on the wall or another car, and it may shift just enough to chew up the belt...
i bought the ebay pack
and put 2 velcrow dots under the battery and no probs
paul
#6708
ebay has g4s packs?? hm..
i just needed to know if people were using sections of wires or if they make battery bars for receiver packs..
#6710
does that hold the cells together or would i have to shrink wrap it or epoxy it to keep it together?
#6711
You would still need something to hold the cells together. Try shoe goo or similar flexible adhesive. Shrink wrap or tape helps to finish the job off - the glue tends to stay a bit tacky and picks up heaps of dust and grit. Covering the whole pack is much tidier for such a good looking car as the G4
#6712
Thanks, I'll try it.
#6713
I went the easy route and bought the ebay pack last night. I'll run my other pack this weekend but with a whole lot of zip ties to make sure it doesn't shift and hit the belt.
#6714
I have uploads some Gansei's photo in Femca 2007 ( in Jakarta ) thread.
#6715
Thanks Edith for giving the great news on the battery packs. Just to let racers know that Raceday Hobbies will have these packs in stock next week !
Please go to our website and view the first page you will see a lot more new items release by Team Magic and K Factory for the G4. Most or all will be in stock next week.
New Duro Gears, New 2 speed housing and shoe set for gears, New A arms for front and rear, New Rear Anti roll bar plus the bulkhead system needed to install the anti roll bar, New G4 Flash pit rear hub set for stock G4's.
Team Magic is on the move again!!!!
#6716
#6718
I wish there was some info on these parts somehwere, I have searched and come up empty handed. I would really like to find out whats new with the gearing and also the enhanements to the clutch. If anyone can shed some light that would be great.
#6719
Looking forward to the upgrades - Hope it will make my G4S even going better than what it is!
#6720
Hi diesel001,
In my G4+, the 2nd spur gear holder & shoes are slightly smaller in diameter, so there is a little more plastic on the actual spur gear, which gives a very precise spur gear (OD is the same). Both spur & holder also have 3 holes in them to save a little weight.
Hope this helps.
Hope this helps.
