Tekin RS ESC sensored
hi guys.
just some question here.
is the Lipo cut off 100% working? is there a safe method that i can try without fear of Lipo getting bloated?
currently i have been only racing 5-10min max and rest/cool down the car after each round.. i would normally charged my battery at same time.
btw how much voltage is low enough to hit the lipo danger zone?
thanks for all your inputs!
In practice with TC I've ran it all the way down to cut off a few times and it worked flawlessly...though I wouldn't recommend it.
ESC issue
What does it mean when the ESC is turned on and all the lights stay lit up? I know it probably says in the manual, but I am at work and thought I would drop a line here to see if I could get a quick answer.
What happened was after a crash into a wall in my onroad car the ESC acted like there was some kind of short in it and would work, but then wouldn't work and now does what is explained above. I feel it may need to be sent in, but wanted to check here first. Thanks everyone in advance!!!!!!!!
Hi there,
Where can i found RS PRO for good price ???
All HK shop are 'out of stock'
Thx
Thx
All lights on and flashing is no signal from the rx.
Manual:
http://www.teamtekin.com/manuals/RSManual.pdf
Manual:
Manual:
Manual:
I wanted to keep it short sorry that it is a bit long
I hope you understand me what I'm telling in my mail.
Greetings, Emiel
Manual:
Manual:
tekin rs
i have two questions, one: is it true when setting up your turbo for your speed control, u must first get the right gearing with out it before you dial in turbo for the straights?
two: i thought u got to choose what your start rpms where; i see u can choose what end rpms u want, but then the program gives u start rpms to select from; is this right?
That's correct. You enter the end RPM you desire, and then hit the "Calc RPMs" button. It will then give you a list of start RPMs to select from.
I've written a guide specifically aimed at beginners on programming the Tekin RS using the HotWire. It is on www.carsrcracing.co.uk at http://www.carsrcracing.co.uk/?p=188
Trev
Trev
