Tire Question
Tire Question
How many of you guys have run The proline bowties in rear and the pro line holeshots up front and what kind of success did you have. Im talking the soft compound. I have a race Sat and was thinking about trying this but not going to have much time to practice before race. Thanks Rick
the bowties would work good in the rear or the front the holeshots in the front proberty would take a lot of foward grip out and steering also thats my guess
Okay let me ask this. How do the soft Hole shots work on a hard and dusty service. Ive used the boe ties and theres almost to much bite. I do have a set of the hard rubber crimefighters but there the older discountined version. Small rim and large tire. They work good but theres a lot of body roll
I have had very good luck with M3 revolvers with AKA or the new blue Pro-Line inserts on just about every surface, including hard and dusty. I have found the stock inserts in revolvers to make the car very unpredictable, but with a stiffer insert, the tire comes to life. Calibers also work well on that type of surface. If the track is really dusty out of the groove, you might not want to go with the hole shots, like Miniracer said, you'll be skating.
Hope this helps,
Chris
Hope this helps,
Chris
I think it would work rather well on a really well groomed hard packed blue grooved track. However, you will run into a real wear issue with the rear tires.
On a different note I have run Double Dees on the rear of my buggy and Crowbars on the front of my car just to try on a crazy blue grooved track with amazing success. Definitely take a look at that setup. BTW JCONCEPTS rules.
The only time I'd run soft holeshots is when there's a moist pack -- they'd be absolutely dialed then.
Wayne
