Vbc D09
#106
Has anyone tried this car out in 21.5 yet?
#107
I have run the plastic parts from the V1, silvers, golds and reds and the durability is very good. I have broken a silver c-hub and steering knuckle, but once I trimmed the DJC stub axle back so it doesn't catch board seems all was well.
I'm not sure if the hard bumper will fit the FF17, but it would be something I'd check into as well.
#108
#109
#110
D07
I know this is a tread for the D09 . I have a question for the D07 and since most on this tread have been with VBC for awhile is the reason for asking about the D07. I run 21.5 class usgt and I was wondering what chassis should I use. I have the car setup with the v2 aluminum chassis with Ryan Maker default setup. Just need a opinion of what chassis would be suited for this class? Thanks for any input.
#111
Ordering parts from vbcracing
Anyone having problems getting parts from VBC racing. Here in USA. placed order like 4 days ago. No tracking # email 2s. No response. Messaged on fb . I got message from someone. From Vbc on fb that they will not address the issue that I am having.
#112
I had an issue and when trying to email [email protected] kept getting message kicked back.
I contacted through FB and was refereed to use [email protected]
Had a message back next day and replacement parts sent a day later with tracking number. I'd say give that a try.
#113
not yet, haven't needed to retire the D08 from my 21.5 class yet. Are you having any issues with it?
#115
Have not run it yet (carpet) but in theory it should take flex out of the front of the car and would be more suited to high traction situations. I would think for asphalt you'd want to stick with the floating mount.
#116
What are the needed parts to mount the direction directly on the chassis?
The user manual point to references I can't find anywhere on Internet.
Are you using D07 parts?
Thx.
Thx.
#118
Thx for the answer.
A VBC pilot told me that it is the following part:
WildFireD07/08 Steering Chassis Mounted Post Set D-05-VBC-0177 | VBC Racing
#119
Thx for the answer.
