Jammin X1 - so close yet so far
#316
Originally posted by Sgt_Morrow
Do you guy's think the screw in hingepins are a must?
#317
lmslms, for tires I like Crimefighters in M2, With the outer row of pins clipped down to about 20% inside and outside rows......or some of the Treadz work well also, especially on loamy or muddy tracks. The Jammin tires are also very good, but the molds are sketchy so look for poor pins, etc to be sure you have a good set........Jim
#318
Originally posted by the buggyman
the problem with the stock pins seem to occur when running other then Ofna rims. The inside of the rims web (support bars) rubs the e clips off when the wheels are fully turned every run. Mine did this with shoe goo.
#319
Or you can purchase the captured hinge pins . I posted this on the grid, but was wondering if anyone else was breaking the servo saver posts (#40511)? I have broke like four now and was wondering if anyone else is braking them? if not sure try turning the screw to see if it comes out. If it just spins then it is broke inside.
#320
Niklas - We've been experimenting with turbo plugs and things are looking pretty promising.
Can't wait to get some of the new motors! I've been really happy with the current ones after we got some of the bugs taken care of..basically, the engines took a lot longer to break in than I thought!
slrguy - I think the Jammin' is probably the best car for my driving style. I am running the stock setup, with the shocks moved in one hole, 5-7-2 diff oils, 60-40 and 53's in the shocks. I don't have a setup sheet on the net yet, but I will make one soon.
Sofast - I'm running a hardcoat JP-2. The best thing I've found so far on a rough track is to use the one degree anti-squat block. It doesn't really change the overall balance of the car like a shock change will, but it helps the car float over bumps.
A dremel with a sanding bit can make any rim fit without knocking off e-clips. Just run the sanding wheel around the inner edge of the rim to sand off some material and it'll clear the pins.
#321
#322
Only you crazy Euro's turbo-tune in the pits..haha.
WHHHAAAAAAAAAAAAA!
WHHHAAAAAAAAAAAAA!
#323
#325
WHHHAAAAAAAAAAAAA!
WHHHAAAAAAAAAAAAA!
"those pit tuners drive me nuts" - so how do you do it then? Just start it up and throw it on the track and come in 5 times in a row to re-tune it? In like Furulund that would take like 5 minutes (fourstroking around the track would do about 45s lap times) and the track warm-up time here is only about 3 minutes. I wouldnt have Magnus scream at me for f*****g up the tuning so he wont have any good track time and get into the groove... It needs to be good within a lap and really good when the heat starts.
No, and I dont use a temp gauge either - only my ears mostly...
#326
I think a combination of both is really needed. Basic set-up in the pits, then fine adjustments after running on the track........After all, if it runs different after running it on the track(ie, "set it richer in the pits"), which it always will, it may need some adjustments regardless of how close it seemed in the pits.........
As far as 1/8th engines........With my Maxys Modified Mega engine I use a 8mm restrictor to tame it a little and add some fuel mileage, Plenty of HP, almost too much.......ALMOST, hahaha......Jim
#327
slrguy - Ugh..I gotta stop typing when I'm tired.
I move the shocks OUT one hole on the arms.
Niklas - I was laughing at the extreme cases..like Kanai. WAAAAAAAAA shut the carb closed, adjust...WAAAAAAAAA hahaha.
We stupid Americans were calling it "turbo-tuning".
#328
Then Kanai took the car apart for a clean up as there was oil and fuel on the chassi - the car had not been on the track - just on the starter box!
#329
Haha..break her in nice and fast so he can start turbo-tuning!
Must be something we don't know..after all, he has done pretty well in his racing career..haha.
#330
W.E.D. Jim you got mail.
