NTC3 with Megatech M-16 engine Help
I have a NTC3 with a Megatech M-16 engine in it, I recently had to replace the 2 speed clutch housing, 2 speed pinion gears and plastic "shaft" gears...I went to start it up earlier,by pulling on the pull start all 4 tires are controlled through the pull before the engine cranks,I never had this happen before.... could there be a problem with anything?
