Tekin RS ESC sensored
#2656
RS esc
Hello, My son runs outdoors rubber tire TC open mod. 4.5LRP X12 big open track, can someone help with good setup for this RS Pro speed control for this motor. Stock settings no HOTWIRE yet. Any HELP. Thanks Ron H,
#2660
RS Pro ESC
I like the RS ESC so much that I bought the 3rd RS ESC 2 weeks ago. It went really well in my 1/10 pan car but this morning, the light appeared dim and there is no sound once I switched on the ESC.
The steering works but I cannot move my BL motor. Has anyone else experience this problem?
#2661
#2662
#2663
Good news for the 12th drivers.
#2664
#2667
Guest
Hi,
1/ When I go through the firmware and plug my Tekin RS PRO in the hotwire; after an update check it says that no update is available... but the version displayed is 180...
Is there a problem?
2/ I'm using a Tekin 6.5T on asphalt (rubber & foam) with my 1/10 only sensored mode... any recommended settings to start with ?
Cédric
Is there a problem?
Cédric
#2668
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Hi,
Is there a problem?
Cédric
Is there a problem?
Cédric
http://www.rctech.net/forum/electric...ml#post5231294
Read post #1867. This should help.
#2669
Guest
Thanks for the reply but... I'm running Windows XP
I uninstalled Tekin Hotwire, then downloaded the "latest" from here :
http://teamtekin.com/hotwire.html
After launching the program, I click Yes to check for updates... it says no updates found for your ESC.
After that I go to the tekin hotwire program and current version is displayed : 180.
2/ Any ideas on the 6.5T recommended settings?
Cédric
Cédric
#2670
You can't download the 189 update yet but if you send me you e-mail in a pm i will send it to you.
