Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree139Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 04-25-2015, 11:57 AM
  #20296
Trader Rating: 61 (100%+)
Originally Posted by QDRHRSE
I only have AE & Kyosho cars so my stock of comparison parts is limited....I took a Kyosho pucks diff and put it in the AE 3 gear. The Kyosho outdrives are longer/wider (bones exactly the same) and would work but the spacing is different in terms where the outdrive bearing sits on the outdrive. There's a slight chance that if I used the Kyosho outdrives on an AE diff gear that it might work. Just to qualify what I mean, an AE diff gear is probably 2 mm thicker. Anyway, I decided that it was too much work for me so I put the stock plastic C & D mounts back on for now. Since my Lite is supposed to be light I decided to abandon the +4 idea for now. I guess it works out because the aluminum c & d mounts weigh more than the plastic pieces anyway. After I get the car sorted out I'll mock up the Kyosho outdrives in a spare tranny and see what happens.
MIP makes the correct bones you need for the +4 mount setup....!
Socket is offline
Old 04-25-2015, 12:25 PM
  #20297
Trader Rating: 515 (100%+)
Would you by chance have the part#?
QDRHRSE is offline
Old 04-25-2015, 01:07 PM
  #20298
Mizchief's Avatar
Originally Posted by jmcelroy42
1500.4g
Is that an RSX with an aftermarket cap? Does the cap give you better performance or did you just need a replacement?
Mizchief is offline
Old 04-25-2015, 01:23 PM
  #20299
Originally Posted by gabc
Any idea if the b5m factory lite is suitable for loose bumpy tracks?
I've driven my friend's b5m on the same track and it handles very well in stock settings. I really like the hopped up parts of the factory lite, but just wondering if it will handle similarly or better than the b5m on such a track.
I'm sure you could set it up for almost any conditions but based on how it is set up I'd say its really meant for a higher grip track the way they sell it. In the winter when traction decreases greatly on our track, we go heavy and set the cars up soft. The Lite is light and stiff.
QDRHRSE is offline
Old 04-25-2015, 02:48 PM
  #20300
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by pink_sleeve
Why do you guys think Cavalieri chooses to run the 94671 .13 metal gear servos over the 94661 .08 titanium gear servos?
Looking at the specs of both servos, I would guess it comes down to servo speed. Maybe he doesn't like a fast servo?
Jmuck69 is offline
Old 04-25-2015, 04:25 PM
  #20301
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
How does the stock setup of the Factory Lite compared to the original B5M? Or what differences have people been noticing so far? All I changed from my stock B5M was the shock pistons, otherwise, very happy with the way it felt.
Dan is offline
Old 04-25-2015, 04:45 PM
  #20302
I think that I need a new scale. Per my scale, my Lite with Ti upper screws, Ti ball studs, pucks, slipper eliminator, KO one10 servo, 2.4 wheels, CF strap, aluminum wheel nuts, and a Trackpower 90c 3250mah lipo, hobbywing 3.1 & Bandit motor weighs 1438 grams (minus wing and transponder). I have another car that is similar but it has a hand milled chassis and it was 1520 with a 4400mah SMC lipo. Is that possible? I might have to drive to Lowes and buy another scale....I'm going to do that right now.
QDRHRSE is offline
Old 04-25-2015, 05:00 PM
  #20303
....forgot, I have a second scale in my track bag. This a different scale and this time I threw the transponder on. You'll see the next pic without a body.
QDRHRSE is offline
Old 04-25-2015, 05:03 PM
  #20304
Here's without a body....
QDRHRSE is offline
Old 04-25-2015, 05:28 PM
  #20305
Originally Posted by Jmuck69
The online instruction manual at Team Associated's website lists what tools are needed.
2mm & 1.5mm
I looked over the instructions but I guess I missed that. Thanks for your help.
What about nut drivers? Are all the wheel nuts 5mm
tekin112000 is offline
Old 04-25-2015, 05:42 PM
  #20306
Jmuck69's Avatar
5.5mm and 7mm. Wheel nuts and slipper nut are 7mm and all others are 5.5mm
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-image.jpg
Jmuck69 is offline
Old 04-25-2015, 06:59 PM
  #20307
jmcelroy42's Avatar
Tekin actually sells 2 different sizes of caps,it's the bigger one,and I jus figured it couldn't hurt, bigger is better right?
Really loving the mid motor compared to the RM I jus switched from, can drive it so much harder (more like a 4x4)
jmcelroy42 is offline
Old 04-26-2015, 01:43 AM
  #20308
HSV427's Avatar
Trader Rating: 30 (97%+)
I was wondering has anyone tried the xfactory carbon chassis, i have a b5m with all the goodies so its really not worth getting the new lite, but my buggy can still afford to lose weight and was wondering would it be worth while getting the carbon chassis or getting the lite chassis any advise would be appreciated as i don't want to lose any of the great handling you get with the stock chassis.
HSV427 is offline
Old 04-26-2015, 02:10 AM
  #20309
Alot of guy's have been having success with Bezerk RC ' S carbon chassis. Won the Australian Stock Title. Contact Paul through Bezerk RC FB page.
71WOK is offline
Old 04-26-2015, 05:13 AM
  #20310
Trader Rating: 68 (100%+)
Picked up my lite yesterday, started the build, the only thing missing is the front bumper. The car is coming together nicely.
Speedychris22 is offline
