Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
Nam Lee Cup 2015 1st Round >
Old 03-11-2015, 10:25 AM
  #16
infinique's Avatar
Mini Class Stock Class 17.5
1. Brushless Motor –
a. 17.5 turn (Open to all brands, must be in original condition).
b. Motor timing - Adjustment allowed (Sensor board modification NOT ALLOWED)
c. Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
d. Wires of speed controller can be soldered directly to motor.
2. Brushless E.S.C –
a. Open "Blinky" E.S.C (Timing and turbo functions NOT ALLOWED)
b. Battery wires can be modified at the bottom of connecter to accept other types of speed controller connecters. Wire length must exceed 3cm.
c. Any attempt to modify or to influence the ability of the E.S.C is not allowed (Inclusive of adding additional capacitors and other E.S.C influencing device.) Only battery plugs can be changed.
3. Tires, Rims and Inserts –
a. Open rubber tires only (NO sponge tires are allowed)
b. NO touring car tires allowed.
c. Tire warmer and tires treatment allowed.
d. Only 1 set throughout the race including final (Tires will be marked each round with sticker or colour)
e. Replacement for damaged wheel (Eg. Cracked, broken) is allowed but subjected to approval from Race Director.
f. Spoke rims only (Any brand so long designed for M-Chassis application).
4. Bodyshells –
a. Only realistic ABC, Tamiya, HPI, Blitz, SPICE mini bodyshell are allowed (NO touring or cartoon miniature type bodyshells are allowed).
b. High Roof (Wing that comes with the bodyshell is allowed)
c. 1-10 scale and 1-12 scale are allowed.
d. All car bodies must be painted and complete with decal sticker.
5. Drive Train & Transmission –
a. Minimum 5.80 Final Drive Ratio cannot be lower than 5.8.
b. Example M05 can use Pinion 18 (6.44) or 16 (7.25) higher than minimum 5.8 is ok.
c. No Speed Gear modification allowed.
d. Front Lock Diff Situation is NOT ALLOWED.
e. Gear differential is allowed.
6. Chassis –
a. M03, M04, M05 and M06 only are allowed. (Short, Medium, Long wheelbase are accepted)
b. Conversion to Evo or other carbon chassis is not allowed.
c. Modification to allow square LiPOs to fit allowed.
d. Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
e. Option parts from Tamiya, Yeah Racing, others are allowed.
f. Clearance under main chassis parts must exceed 3mm before the race.
g. Any form of driving aid is not allowed to be use. (Eg. Gyro, Active Steering Assist Unit)
h. Min Weight - 1200g (Ready to race with transponder and bodyshell)
7. Batteries –
a. 2S 7.4v LiPos, 6.6v LiFes, NiMH are allowed (Only hardcase or enclosed type batteries).
b. Shorty packs are allowed.
c. Tamiya oval type LiPos allowed, Square type LiPos allowed.
d. Resting voltage of 2 cell LiPo should be NOT MORE than 8.44V.
8. Race Format and Condition -
a. All cars’ weight will be inspected after each race.
b. 3 Rounds of Heats (5min)
c. Fastest Time Qualifying (FTQ)
d. 3 Finals for A Main (2 best out of 3)
e. 2 Finals for B Main (1 best out of 2)
f. 1 Final for C Main
g. Top 3 fastest cars will be inspected by Race Organizers (Motor, battery, ESC).
Important Remarks: NO house transponders provided. Racers are required to bring/buy their own.
M-Chassis Race Motto: M-Chassis should always remain as a fun and realistic class. NLC M-Chassis race emphasises on genuine speed (Not hanky-panky modifications) and tuning flexibility on option parts. A race winner who is respected with fairness in mind.
infinique is offline
Old 03-11-2015, 10:28 AM
  #17
infinique's Avatar
Formula 1 Class
a. Speed Passion CONTROLLED ESC (Stock Club Race version only) + MOTOR (17.5T) COMBO
b. Motor timing adjustable allowed (Motor Timing Board Modification not allowed)
b. Only 1 set throughout the race including final (Tires will be marked each round with sticker or colour)
c. Replacement for damaged wheel (Eg. Cracked, broken) is allowed but subjected to approval from Race Director.
4. Bodyshells –
a. F1 Scale with molded front & Rear Wing (no handmade wings allowed)
b. All car bodies must be painted and complete with decal sticker.
a. Solid Axle drive system. Full independent rear suspension system is not allowed
b. Open gear ratio
6. Chassis –
a. Tamiya F104, VBC Flash, HPI F Ten, Yokomo YRF001…. Etc
b. No-IFS Suspension system
c. Option parts made for the car are allowed only.
d. Clearance under main chassis parts must exceed 3mm before the race.
e. Any form of driving aid is not allowed to be use. (Eg. Gyro, Active Steering Assist Unit)
f. Min Weight - 1100g (Ready to race with transponder and bodyshell)
7. Batteries –
a. 2S 7.4v LiPos, 6.6v LiFes. (Only hardcase or enclosed type batteries).
Old 03-11-2015, 10:59 AM
  #18
infinique's Avatar
Realistic Touring Car 17.5 Open
b. REALISTIC SPOKES rims only (Any brand so long designed for Touring Car application).
4. Bodyshells –
a. Only realistic 1-10 Sedans, BTCC, Japan Touring, Japan GT, Rally, Drift, bodyshells are allowed.
b. NO touring car type bodyshells example ProtoForm M6, Dodge, LTCR, Mazda GX, Blitz...
b. Original Wing that comes with the bodyshell is allowed.
c. Must be 1-10 scale 190-200mm.
a. Open Final Drive Ratio.
b. Must be 4WD either Belt or Shaft Driven.
c. Gear differential, One Way Diff is allowed.
6. Chassis –
a. Open to all 1-10 touring cars and brands (Bath Tub, Carbon, Aluminium all accepted).
b. Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
c. Any form of driving aid is not allowed to be use. (Eg. Gyro, Active Steering Assist Unit)
h. Min Weight - 1500g (Ready to race with transponder and bodyshell)
7. Batteries –
Realistic Touring Car Motto:
Realistic Touring is to reintroduce the very successful SSGP concept powered by open Brushless System and open 17.5T running Zero Timing. NLC is introducing this as a new class which emphasizes on realism speed with beautiful real car bodyshells and spoke wheel combo. If you have LEDs its even better to make your ride outstanding which is why we have approved for minimum weight of 1500gsm. Time to Pimp Your RC!
Old 03-11-2015, 05:05 PM
  #19
infinique's Avatar
Remarks:
1. All Classes Are BLINKY Non Boosted Only.
2. Only 1 set of tires for the whole RACE including qualifying and Final.
3. Please check and update all your PT Number
4. Your participation is secured only when it is PAID, so please pay early as there is limited 100 entries for all classes.
• M-Chassis 13.5T Closed (SpeedPassion Club Race Combo Set)
Name/Car/PT/Club/State
1. Ateromen/M05/PT6605200/Sondol RC Team/KL
2. Shukri/M05/PT rent/Sondol RC Team/KL
3. Joe Aziz / M-05 / PT xxxxxx / Geng Songkok TITIWANGSA
4. Wakuda san / M-05 / 4849413 / Geng Songkok TITIWANGSA
5. Wafie / M05 / PT XXXXX/ Geng Songkok TITIWANGSA
6. Sham Sakura/MO5-V1/PT 4842920/ Geng Songkok TITIWANGSA
7. Jimmy Cheng/abc/(PT -Rental ) /Team Z
8. Naz/Mo5/PT5150395/Team(. )
9 FAIZAL Aziz/Mo5/PT (rent)/Team PADDLE POP
10. FIRHAN/MO5/PT (rent)/Team PADDLE POP
11. Amran/M05/PT rent/Sondol RC Team/KL
12. HKS/MO5VG/PT BUYING/TEAM NAM LEE
13. KENNETH LIM/MO5VG/ PT 3720766/TEAM NAMLEE
14. Mun Wai / M05 V2 / PT5392209 / Team Nam Lee
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
• M-Chassis 17.5T Open
1. Clavin Ong / PT ( rent )/Team Nam Lee (PAID)
2. Louis Tan/Gambado/7888888/Team PJ
3. Nicholas Lim/Gambado/PT 8678773/Team PJ
4. Ayep/Mo5 -V2clone/Pt xxxxx/ Geng Songkok TITIWANGSA
5. Marcus Tan/PT-6101918/Team Nam Lee
6. Ryan Tan/ PT-9159334/ Team Nam Lee
7. Kris / PT-3348689/Team Nam Lee
8. K.K LAU / GAMBADO/ptxxxxxx/team NL
9. KRISTIAN LAI /mo5 g/ ptxxxxx/ team nam lee
10. Jackie chan / mo5 v2/ptxxxxx/team nam lee
11.Keong / Mo5 v1/ ptxxxxx/team nam lee
12. Ah teck / Gambado/ ptxxxxx/team nam lee
13. Kok Mun Cheong / M05 / PTxxxxxxx / Team Nam Lee
14. Felix Liew / Gambado / PTxxxxxxx / Team Nam Lee
15. Yip / Gambado / PT xxxxx / team nam lee
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
• Realistic Touring Car 17.5T Open
1. Ajiq/T4 15/PT Rent/Sondol RC Team
2. Fitrie/T4'13/PT4040914/KR/SEL
3. Louis Tan/Awesomatix/7888888/Team PJ
4. Max Teo/Awesomatix/3339333/Team PJ?
5. Nicholas Lim/Awesomatix/PT 8678773/Team PJ
6. Wan/416/PT Rent/LanunSRC/Johor
7. Ella/416/PT Rent/LanunSRC/Johor
8. Mus/S411/PT Rent/LanunSRC/Johor
9. M.Yunus/T311/Pt 2937675/patato chips/N9
10. Haris/T4/PTXXXXXX/Raybrig Nsx Concept-GT/Cyber
11. Nabil/T4 15/PT****/Sondol RC Team/KL
12. Mun Wai / TRF419 / PT5392209 / Team Nam Lee
13. Lee Choon Meng/ PTxxxxxxx / Team Nam Lee
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
• Formula 1 17.5T Closed (SpeedPassion Club Race Combo Set)
1. Zack Uzaini/SP/PTxxxxx/HSRCC/SEL
2. Max Teo/Xray X1/3339333/Team PJ?
3. Louis Tan/Xray X1/7888888/Team PJ (Insurance if Touring not running)
4. Kangkung / X1 / 2586951
5.
6.
7.
8.
9.
10.
CLOSED
Old 03-11-2015, 08:37 PM
  #20
CLASSES (All Zero Timing Only):
6 .Sham Sakura/MO5-V1/PT 4842920/ Geng Songkok TITIWANGSA
7.jimmy Cheng/abc/(PT -Rental ) /Team Z
8.Naz/Mo5/PT5150395/Team(. )
10.FIRHAN/MO5/PT (rent)/Team PADDLE POP
15.M_Salleh/m05v1.5/Pt4492687/Team Max ep/cyber
16.Oyang / M05V1.3/Ptxxxxxx /Team Max ep/Dota 7.1.16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
1. Louis Tan/Gambado/7888888/Team PJ
2. Nicholas Lim/Gambado/PT 8678773/Team PJ
3. Ayep/Mo5 -V2clone/Pt xxxxx/ Geng Songkok TITIWANGSA
4. Marcus Tan/PT-6101918/Team Nam Lee
5. Ryan Tan/ PT-9159334/ Team Nam Lee
6. Kris / PT-3348689/Team Nam Lee
7.Clavin Ong / PT ( rent )/Team Nam Lee
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED
bob matt is offline
Old 03-11-2015, 09:47 PM
  #21
bee-man's Avatar
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
14. Syamson AR/ PT**** / Team GBC
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED
bee-man is offline
Old 03-11-2015, 11:15 PM
  #22
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
15. wong kok wai / awesomatix A700EVO2/ Team PJ
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED[/QUOTE]
slowturtle is offline
Old 03-12-2015, 03:08 AM
  #23
17. Adwin Wong / Gambado / PTxxxxxx / SSR
18. Herman / M05V2 / PTxxxxxx / SSR
19. Alex Saw / M05V2 / PTxxxxxx / SSR
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED[/quote]
RCGetaway is offline
Old 03-12-2015, 03:44 AM
  #24
17.
18.
19
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
14. Adwin Wong / Gambado / PTxxxxxx / SSR
15. Herman / M05V2 / PTxxxxxx / SSR
16. Alex Saw / M05V2 / PTxxxxxx / SSR
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED[/quote]
Old 03-12-2015, 04:14 AM
  #25
17.
18.
19
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
16. Adwin Wong / awesomatix / SSR
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED[/quote]
Old 03-12-2015, 05:28 AM
  #26
17.
18.
19
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
17. Cikgu Mie/M05v0.9/PTxxxxxx/
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED[/quote]
Woss Tatt is offline
Old 03-12-2015, 07:20 AM
  #27
fattini's Avatar
1. Jimmy Cheng/abc/(PT -Rental ) /Team M@M ( PAID)
2. Ateromen/M05/PT6605200/Sondol RC Team/KL
3. Shukri/M05/PT rent/Sondol RC Team/KL
4. Joe Aziz / M-05 / PT xxxxxx / Geng Songkok TITIWANGSA
5. Wakuda san / M-05 / 4849413 / Geng Songkok TITIWANGSA
6. Wafie / M05 / PT XXXXX/ Geng Songkok TITIWANGSA
7. Sham Sakura/MO5-V1/PT 4842920/ Geng Songkok TITIWANGSA
17. Micheal/abc/pt rent /Team M@M
18. Jacky/abc/pt rent/ Team M@M
19
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
18. Ryan Loi/mo5/pt rent/Team nam lee
19. Wesley Wong/Abc /pt rent/ Team W@R
20. Rabindra/Mo5/pt rent / Team W@R
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED
fattini is offline
Old 03-12-2015, 06:29 PM
  #28
19
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED•
21. SKNg/Gambado/PT 2981459/Klang
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
17. YCNg/Xray/PT 8591963 / Klang
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED
Updated
1266lipo is offline
Old 03-12-2015, 06:33 PM
  #29
19. Cikgu/xxx/PT/TeamKR
20. Adik Haikal/xxx/PT/TeamKR
21. Pejal/xxx/PT/TeamKR
22. Adam/xxx/PT/TeamKR
23. Iliyas/xxx/PT/TeamKR
24. Fendi/xxx/PT/TeamKR
25. Roslan/xxx/PT/TeamKR
26. Rambo/xxx/PT/TeamKR
27.
28.
29.
30.
CLOSED•
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
5.
6.
7.
8.
9.
10.
CLOSED
iliyas308 is offline
Old 03-12-2015, 08:09 PM
  #30
infinique's Avatar
27.
28.
29.
30.
CLOSED•
12. Lee Choon Meng/ PTxxxxxxx / Team Nam Lee
13. Adwin Wong / Gambado / PTxxxxxx / SSR
14. Herman / M05V2 / PTxxxxxx / SSR
15. Alex Saw / M05V2 / PTxxxxxx / SSR
16. Cikgu Mie/M05v0.9/PTxxxxxx/
17. Ryan Loi/mo5/pt rent/Team nam lee
18. Wesley Wong/Abc /pt rent/ Team W@R
19. Rabindra/Mo5/pt rent / Team W@R
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
CLOSED
Minimum 8 Entries
5.
6.
7.
8.
9.
10.
CLOSED
