Proline Pro2 no-prep drag
#16
Got the body cut out and mounted. Love how it sits
#17
#18
Those colors came out great.
#20
#21
Nice one mate. Can I ask how you have yhe front sway bar attached at the bottom? I dont think the traxxas bandit arms I have installed will allow for it
#22
Some scale realism with the Headlight intake
#23
I decided to change the motor to another one I had, however this one had a 5mm shaft. I had previously used a spur gear from the Jato on my Traxxas slash so thought I would see if I could do the same on the Pro-2. However, to do this, I need to use the out-drive shaft from the slash that the Spur gear mounts to as the spur gear is held on with a different method (small pin).
On the left is the Pro-2 gear box, on the right a traxxas slash gear box. The main diff gears are basically the same on both - same amount of teeth and same pitch, so I decided to leave it in there. I swapped over the two gears on th top left of the image below and it seems to work perfectly. Meshes well and is nice and smooth. I did have to add 3 small washers to the longer end of the shaft to get rid of a small amount of play.
And with it mounted
I've used a 56T spur as this is about as big as I can go before it'll start rubbing on the axle. Paired with a 16T pinion.
And with it mounted
#24
I've also down a bit of work on the body, added a drag spoiler and am mocking up some drag chutes
#25
Had it's first run today and seems to run quite nicely. I've also swapped out the motor for a 4000kv one.
Got the parachute finished and mounted and really like how it looks. Also added some bracing for the spoiler
#26
Thanks mate! Yeah I'm pretty happy with it! I might have a go at making a wheelie bar to complete the look
#28
How does it run without one? Wheelie bars are kind of like medical insurance, insurance is the reason we can't afford the medical bills and need the insurance to pay for it. Hanging a big old wheelie bar off the back end will make the front lift more than if it were not there in the first place and therefore necessitate the need for the wheelie bar to actually work properly. A carbon bar would be really cool and compliment the high-tech aesthetics well.
#29
