Need help understanding what power supply to get...
I PICKED UP AN LRP PULSAR SPORT TODAY!!! Seems to be a good charger!
In the instruction manual it says to use no more than 15V but I've read get a 12A power supply for it...Now wouldn't this fry the charger then?!?!
If I used a 5A power supply, would that mean I can only charge 5A into my packs? Now I saw a Rivergate PS today and it was 30AMP....Can someone describe to me what I should be looking for to run my charger...
Aaron
Aaron
your fine as long as it is a 12v 12amp. the 15v reafers to voltage most power supplies are 12v. I have a 12v 30 am which is its output. If you plan on getting a second charger then you would need to get a 25amp or 30 amp power supply. with your current power supply I think that if you got a 2nd charger you would only be able to charge at like 4.5 per charger.
Volt and amps are different things.
Your charger accept 15 volt as maximum. So 12 volt should be fine (however there's a minimum somewhere too).
The power supply should be able to deliver the amps you would like to charge with. Usually, it's good to have 0,5-1 amp more from the power supply, than you need for charging.
So if you want to charge with 7 amps, you need a 7,5-8 amp power supply.
THANKS!!!
