Serpent S411
#3406
#3407
Most of the time I have the body trimmed to the cut lines and mounted, I make sure the nose is solid and has little flex, use a third mount to keep the hood from sagging. Then with the tires on the car (ride height set) I run a sharpie around the body to see how far out it is, which by all accounts is about 4mm more trimming.
#3408
after tie up the wheel. its feel like bearing jam, so i rebuild all 4 upright. before tie up the wheel, its smooth..tie up again problem occur.how to solve it??? my te is almost new. my experience tell me is the pin hole of wheel adaptor too deep yet it lock up both bearing after tie up the wheel..really upset on it.
#3409
that's just it, if the ride height is set at 5mm and you run a sharpie around, which is @ 6mm. the body is 1mm above the chassis ride height. now my next question is would this be illegal because the body has been cut above the cut lines? i thought the cut lines have to be used to meet the body specs for competition?
After I do a trim like that, if you take the wheels off the car and put it on your setup board there is little to no gap between the body and the board. (When the body is pinned on the chassis). You could slam the body but first you wouldn't make the minimum body height measurement and chances are real good that the front wheels would rub the upper front fenders causing even more problems.
#3410
Tim Potter you have a LE kit, have run into this problem??
#3411
I have not finished bulding it, but was informed of an issue with the front wheel hexes/axels that bind when tightened. They are working on a fix.
I am putting the front end togther today, so when I get it done, I will check it out and report back.
If you could post some pics we could maybe come up with a fix.......but I would contact Serpent to let them know about the problem so they could fix you up. This could be another known issue as to why the LE is on hold.
#3412
S411te
//img36.imageshack.us/img36/8943/lafotoxn.jpg
Here you hace a photo of the temporary solution, serpent appears to have recognized this problem or defect and a rear differential q the new covers are wider and that makes q the Rear back will not get soft if more than 2 degrees or plate convergence less than 3 degrees
#3413
#3415
Just to share with you guys, last weekend's race I TQed and won in one of the big race in my neighbouring country. It was a controlled motor class race (using Dualsky 10.5t) in an indoor carpet med size track. My car was flawless all weekend.
Here are the videos.....my car starting from pole (Fluorescent Yellow/Green + Blue) Final Leg 1 @2:15 had a bad moment with the back markers but managed to climb back to win the round.
http://www.youtube.com/watch?v=iBS5SPQipeQ
Final Leg 2
http://www.youtube.com/watch?v=Qbb504XzU2w
Final Leg 2
#3416
Final Leg 2
Final Leg 2
#3417
Final Leg 2
Final Leg 2
The red car was dogging you for some time. Good job in holding it together.
#3419
TE fixes
So, is there an estimated time Serpent will have the Team Edition "fixes" sorted out and have the kits shipping again?
I am looking to get one but would like to wait until the issues are sorted out.
