Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 08-21-2012, 05:52 AM
  #451
carbons2k's Avatar
Trader Rating: 21 (92%+)
Originally Posted by gelshocker
Pick up one of the latest RB5 setup sheets, and you'll need to dremel the original front tower to free up the big bores and build a +13mm chassis. Body is not Kyosho it is Proline bulldog. Not to mention the NCG arms will set you back a fair coin, whereas RB6 comes with gull wing arms stock. Though RB5 parts will be in ample supply I expect RB6 setup development going forward.
I never said you can't run the car box stock either, more power to you
Ok you don't NEED the +13. Guys at my local track are running the stock chassis and they're the fastest guys around. The front tower gets dremeled bc guys with the WC use the older shock tower so it needs to be dremeled. If you use the tower that comes with the kit, it does not. And are you seriously going to argue over the body? A few locals run the stock body and are quick. The bulldog does have better downforce tho. I would say 95% of people change the body, no matter what car it is. Body change is irrelevant. The b4.1 wc even comes with a bulldog now. I happen to run the finnisher.
It's the same as any other car. When I had the 22 I added about $60 worth of hop ups before it felt decent. My rb5wc... $4 shock tower. Ran the stock body for a month and STILL felt better than my 22.
carbons2k is offline
Old 08-21-2012, 06:04 AM
  #452
carbons2k's Avatar
Does anyone know if the rear hubs from the rb5 will fit the rb6?
Old 08-21-2012, 06:18 AM
  #453
Raphalite's Avatar
According to the manuals, the alu. Rear hubs listed on the optional parts page are carried over from the rB5.
Raphalite is offline
Old 08-26-2012, 09:11 AM
  #454
umm winning's Avatar
Wondering the same, why not just include the aluminum's with it... or will there be a rb6 WC in early January with alum goodies?
umm winning is offline
Old 08-26-2012, 09:21 AM
  #455
K_King's Avatar
Trader Rating: 47 (100%+)
The hubs will fit yes
K_King is offline
Old 08-27-2012, 10:29 AM
  #456
Trader Rating: 166 (100%+)
Most guys at OC/RC that run Kyosho (all two of them) are running the stock chassis and find it just fine for stock, One guy TQ'd and I assume won with his stock RB5 SP2 WC (didnt stay around for mains since I got taken out by a sandbagger Losi driver running stock class and broke a carbon front arm which the shop didnt have in stock.
jpcopeland1 is offline
Old 08-27-2012, 03:03 PM
  #457
Any of you guys that have actually seen the rb6 be able to tell how much room there would be for the esc in the space provided and under the shell as it looks really low in that area. I use a HW xtreme stock with fan but not sure it will fit in (looking to run mid motor btw)
losi8lunie is offline
Old 08-27-2012, 03:06 PM
  #458
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Im not sure anybody has gotten a nice in person look at the RB6 built in mid motor. I got to fondle Tebo's car at nats, and there appeared to be a lot of room for a standard size esc, but it was of course built in RM. You would need to take a close look at the pictures.
You likely wont need to run the esc fan in 2wd, by the way.
Cpt.America is offline
Old 08-27-2012, 03:14 PM
  #459
Thanks for the quick reply, looking at the manual the esc looks to be in a similar position in both configurations so it might be ok. Oh and I need the fan as I race indoors on carpet with a lot of boost!!
Old 08-27-2012, 03:33 PM
  #460
I race indoors on very high traction clay... and for a while I was running a 7.5... no fan needed on my speed passion or LRP esc. Considering the battery strap goes OVER the ESC... i don't think you will be able to run a fan. But, that's just speculation. I don't drive the car yet.
Old 08-27-2012, 04:44 PM
  #461
pli
Saddle packs or stick, which type would you think works best in the RB6? Maybe it's hard to guess before anyone has had a chance to drive the car, but feel free to share your opinion anyway I know both types will fit in the RB6 (in both configurations as far as I can tell), but I'm more interested in difference in handling, flexibility, etc, if it's possible to say something about that.
pli is offline
Old 08-27-2012, 04:47 PM
  #462
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Has anyone heard if it is still scheduled for September?
Posvar is offline
Old 08-27-2012, 04:55 PM
  #463
asc6000's Avatar
Trader Rating: 15 (100%+)
the general opinion on the rb5 seemed to be stick but with the rb6 having the lower cg alu chassis that could change. as you said, can't tell for now.
asc6000 is offline
Old 08-27-2012, 05:15 PM
  #464
pli
Yes, I've been told I will receive mine on September 14th, possibly a day or two earlier.
pli is offline
Old 08-27-2012, 05:31 PM
  #465
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
everone ready for the RB 22
Pete Martinez is offline
