Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 07-20-2009, 02:48 AM
  #451
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Alfie
It supposed to soften the foam so that the tires would work better for that first few minutes.
The setup is a combination of the friction plate, damper, to find the balanced setup for front and rear.
Alfie
I tot so. Apparently, on a general observation, all the guys running 104 yesterday had a higher wear rate on the fronts. They near the rims after 4-5 packs of say about 7 minutes of runtime each.
See you this sunday. Boy i have much questions for you.
Arahawak is offline
Old 07-20-2009, 02:55 AM
  #452
alan1467's Avatar
Is there any way to run the F103 front wheels/tyres to try the different compunds? I killed a new set of kit tyres in less than 30 minutes track time but only 2mm off the rear
alan1467 is offline
Old 07-20-2009, 03:30 AM
  #453
Arahawak's Avatar
At the moment, i think not. I think somebody tried to squeeze the 103 fronts foams on the 104 front wheel. no feedback yet..
Basically the 103 front rims are too small for the 104 kingpins, so that's why it wun work.
Arahawak is offline
Old 07-20-2009, 04:25 AM
  #454
Originally Posted by Arahawak
I thought that traction compound would worsen the tire wear, since it is suppose to give more grip?
or it is suppose to give more grip and have better tire wear?
now i am confused..
i thought so, same as rubber tires if we use paragon fx.
it softens the foam, = more wear i think.
looks everyone here has same problem with the front tire.
would try the harder one (type B)
running F104 is a lot of fun, but..
change front tire every race day = not fun anymore..
krat is offline
Old 07-20-2009, 10:30 AM
  #455
JayL's Avatar
What arbor works? I tried the d-drive one for f103 my buddy had and it worked for the rears, but the front rim hole was too big for the arbor to hold
Ran my F104 with 17.5 first time. Pushed alittle as the rear was stuck but tightening the nut on the top damper plate thing helped alot.
I ran 4 runs of 6 mins with hardly noticable front tire wear, high grip asphalt 160'x90' track
JayL is offline
Old 07-20-2009, 07:11 PM
  #456
Arahawak's Avatar
was it this that you got?
http://d-drivesportsenglish.com/inde...roducts_id=438
Arahawak is offline
Old 07-20-2009, 07:24 PM
  #457
Patriiick's Avatar
to a degree yes, but in reality not necessarly.
Foam tire wear in front comes from scrubbing/lateral friction.. that is to say the friction generated by the angle of the wheel and the grip of the tyre.
By using traction compound, you give the tyre more grip, hence more turn-in for a given degree/angle of steering.
If you reduce your steering throw (less epa) while having more inherent grip, you will keep decent handling specs while reducing a little the wear.
it will not be perfect, but it will help.. !
Patriiick is offline
Old 07-20-2009, 07:46 PM
  #458
oh i see. yes it does make sense now.
krat is offline
Old 07-20-2009, 11:36 PM
  #459
fatboy's Avatar
hi Guys,
We have setup a new blog for the F1 which we hope more of u guys to share your comments and photos with us.
here the link : http://rrcf1news.blogspot.com/
fatboy is offline
Old 07-21-2009, 12:14 AM
  #460
VooDooPH's Avatar
Trader Rating: 18 (100%+)
anybody have a sphere mounted on an F104? also, what spur/pinion is everyone running for 17.5 and 13.5?
VooDooPH is offline
Old 07-21-2009, 02:16 AM
  #461
Alfie's Avatar
Trader Rating: 17 (100%+)
I think the wear rate is on both your driving style and toe-in/out you set for your F104.
For me, I like to throw the car when I really need to take the corner tighter to overtake, but any other times, I will drive smoother into the corners to reduce my pocket wear (for the obvious reasons).
I never use those traction compound also for the same reason: pocket wear. The only time I remember using it was at a carpet race.
Besides our topic, you guys should have realised that Tamiya made a bigger wheel set for the F104. And for that, they came out with thinner tires. I see it both ways; big wheels so when the foams wore out, it would not scrub the chassis, thin tires to keep changing tires.
I'll try to help in whatever way I can.
Alfie
Alfie is offline
Old 07-21-2009, 02:19 AM
  #462
Alfie's Avatar
For all you know, the weight of the damper oil plays a big part of the steering, and in turn, affects the wear rate of your tires.
Alfie
Alfie is offline
Old 07-21-2009, 02:33 AM
  #463
Arahawak's Avatar
Alfie
I would like it if they are still able to use 103 tires.
Arahawak is offline
Old 07-21-2009, 02:54 AM
  #464
Alfie
what weight should we use as start point?
is the friction grease also important?
krat is offline
Old 07-21-2009, 09:25 AM
  #465
JayL's Avatar
correct
JayL is offline
