Team Orion CRF Wasp Rev X-Dyno results
#1458
Hey Guys,
well i think i got this engine running to its best performance now to what i can achieve... i think i need more slip on the clutch just to take the bog near the bottom thou what i need to know is that this engine likes to be run HOT - at the moment it runs best at 290F - thats 145 Degrees
Might just richen it up in the top end as i did notice the plug a being a tab WHITE on the plug filerment!
How do your temps compare to mine?
i have had 4 litres of fuel done through this sucker CRF Josh Cyrul WC specs - and have the combo of the following:
CRF PIPE - Josh Cyrul WC
CRF - Plug No. 6
Team Magic G4S/G4+ - King of Bling
Team Magic - RED Shoe Clutch
Team Magic - BLACK CLUTCH Spring
All weights in
Cluctch gap - easy 0.5 - 0.8 might need more so it hits the meat section of the power band down low!
Overal its been hard to tune, but once i got the sweet spot yesterday she power slides hard in mid corner!
Ohhh yeah gearing is another thing!!!
CRF - Plug No. 6
All weights in
#1460
Ok guys, just wanted to post my runnings with this engine. Its been about 6 months that i've been racing with this engine. I think i've sorted out most the way this engine works out. though, sometimes reading and doing, is waaaay different. I only have one problem now to solve, I keep breaking plugs, only lasts me about 3 races. and it breaks after I finish a heat, like once I cross the finish line and my car sits while waiting for others to finish, the motor will cut out. Here is my setup I run.
Kyosho v-one RRR.
Crf 2006 one of the first versions with updated HSN holder.
HSN 2.5 turns out.
LSN 5.5 turns out.
CRF 7 plug.
20% Mugen Fuel (made by Byrons I think)
.1 head shim.
RD Logics TurboII Pipe and header
15/61 1st gear
21/55 2nd gear
Kyosho weights drilled out to 3.5 mm holes.
1 set screw added to each.
~.5 clutch gap
~.1 endplay.
JP super hard spring, tightended down almost all the way, but not so much that the spring binds when the clutch kicks in.
Gray clutch shoe.
the motor is a beast. I know my needle settings are WAY off factory but it runs like a champ. Puts me in the A-main at my local track. now, according to the HSN setting i have, it should be running lean, but when I check a new plug after about a tank of running, the plug reads perfectly. slightly wet on the base of the plug, and tannish. After about 3 or 4 more passes, the plug starts to warp. Maybe I need to run .2 shims instead of .1
Im not too concerned that my needles are so out of factory, cause thats what the motors runs best at. Anyone got ideas? oh, and im only hitting about 270 degrees F.
Kyosho v-one RRR.
HSN 2.5 turns out.
LSN 5.5 turns out.
CRF 7 plug.
.1 head shim.
15/61 1st gear
21/55 2nd gear
~.5 clutch gap
~.1 endplay.
Gray clutch shoe.
#1462
Only if you want to start the engine, the plug's wire doesn't make electrical contact anymore, so it will not glow anymore......
#1463
Yeah, I get the same feeling about the head clearance. I think what I'll do is run the factory needles again and retune from there. if i my plug still deforms, i'll run .2 shims.
#1464
CPD
Dear All,
Any body have used the CPD on a CRF??
#1465
Nano,
In Switzerland where I can get the conversion kit for the Orion 80000 to converto to the 2007 version??
Can you provide me the P/N??
Timothy
Timothy
#1466
what?
what?does this thing really exist?
#1467
Nano,
Where in the US can i find the new CRF pressure chanber??
