Team Losi JRXS
Old 10-15-2005, 10:24 AM
  #8326
TheCoolCanFanMan's Avatar
Originally Posted by Sokool
Here is what is on the Losi site for a sample wireing layout.
HHMMMMMMM!!!!!!! That's exactly how I have mine set up, but have noted that one of the losi boy's over here had turned the servo over so the wire came out to the left avoiding the belt and placing the receiver on the same side as the speedo as pictured, but don't seem to see a Cool-Can-Fan
TCCFM
TheCoolCanFanMan is offline
Old 10-15-2005, 10:41 AM
  #8327
JRX-S Bill Thanks I did just that.
Also I am sure this has been asked before but what do I need to build a Spool for the front of my car?
Thanks Tracey
Traceyf is offline
Old 10-15-2005, 11:19 AM
  #8328
Thanks Tracey
use some 150 sand paper cut to the same external size of your diff rings and a hole in the midle of them to go over the pulley collar, hope this makes sence
TCCFM
Old 10-15-2005, 02:59 PM
  #8329
TimmyMontoya's Avatar
I have a gearing question.. I was useing a monster stock motor and had it geared perfectly with a 128\26 for my local track. Now I switched motors to an epic roar stock motor and I cant seem to find the right gearing for it? Can anyone help in witch direction I should be going(up or down)? Thanks for any help....
Tim
TimmyMontoya is offline
Old 10-15-2005, 04:11 PM
  #8330
Mike Haynes's Avatar
Tim
A 26 seems very VERY small for a mosnter, maybe you mean 36 or run on a really tight track? Anyways i usually gear a roar 2 teeth less then a monster.
Hope that helps.
Mike Haynes is offline
Old 10-15-2005, 04:49 PM
  #8331
i have a 28 on mine and ...is your track about 75 foot long straight?
R/C Anonymous is offline
Old 10-15-2005, 04:57 PM
  #8332
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by T. Thomas
Has the Losi JRX-S changed? I saw how the Losi crew was running the rear engine version at the nats. Is this a better set-up for the car?
Marcos.J is offline
Old 10-15-2005, 04:59 PM
  #8333
110 foot
I have run at smaller tracks, like 65foot, and still ran a 32. I must just like to gear hard.
Old 10-15-2005, 07:13 PM
  #8334
geeunit1014's Avatar
Trader Rating: 14 (100%+)
mine is kind of like that, but my battery posotive is in the front, o well still looks pretty
geeunit1014 is offline
Old 10-15-2005, 07:51 PM
  #8335
drew85's Avatar
Originally Posted by Marcos.J
Ya I think they are coming out with a new one but I would like to know when
drew85 is offline
Old 10-15-2005, 09:22 PM
  #8336
RCknight's Avatar
Default I wish they would scrap it.
Come on a 3 layered deck? It screams tweak machine to me. The centered mass design doesn't make a difference anyway. The chassis has to be wider, which makes it hard to fit electronics on it. I use to be a Losi sedan fan. It's just not worth it, but that's just my opinion.
RCknight is offline
Old 10-15-2005, 09:27 PM
  #8337
drew85's Avatar
The "new" one looks just like a old car i once drove, pro3 anyone lol
drew85 is offline
Old 10-15-2005, 09:48 PM
  #8338
TCR
is ford better then chevy
Honda better then Toyota?
It's going to be a matter of opinion no matter who you ask.
TCR is offline
Old 10-15-2005, 09:52 PM
  #8339
Yes I run on a very small carpet track with foam tires. I think the dimentions are 36 by 60.... but overall an epic roar stock should be 2 or so teeth less than a monster... Thanks
Tim
Old 10-16-2005, 08:33 AM
  #8340
RCknight's Avatar
Default I want my revised XXX-S back and....
a cf pro level conversion!
RCknight is offline
