Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree139Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-31-2014, 11:06 AM
  #7591
rigor's Avatar
Trader Rating: 44 (100%+)
Edited / Deleted due to confusion & incorrect info
rigor is offline
Old 03-31-2014, 11:10 AM
  #7592
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Originally Posted by rigor
It's referring to running the rear hubs in the Forward, Middle, or Back position on the outer (wheel) position hinge.
Actually Jesse, its the position of the front caster block. You shim it differently to maintain wheelbase. AE shouldnt have said "rear casterblock" It should have just said casterblock.
Matt Trimmings is offline
Old 03-31-2014, 11:11 AM
  #7593
Dan Hamann's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Chris Gierse
I understand that part. What I don't understand is the last column.
The rear shim on the [front] caster block. Not the rear of the car. To maintain overall wheelbase, you adjust the caster block spacing to counter the movement of the axle with the different trailing positions. The "Rear Caster Block Wheelbase Shim."
Dan Hamann is offline
Old 03-31-2014, 11:15 AM
  #7594
1evo RRR Driver's Avatar
Trader Rating: 11 (100%+)
Default avid slipper??
Fellas quick question, is the avid triad slipper clutch a direct bolt on for the b5?? Seems to have every buggy listed accept the b5!! But it came up when i searched b5 parts
Thanks oh and what one slipper different or better than the next?
1evo RRR Driver is offline
Old 03-31-2014, 11:27 AM
  #7595
Grasschopper's Avatar
Trader Rating: 54 (100%+)
I run the Triad on my B5...use the kit slipper spring and washer and you're good to go. The Avid spring fits fine but the washer doesn't fit the end of the top shaft as it is now larger than the old one. I'm sure AVID will update the part at some point but for now just use the kit spring and washer.
Grasschopper is offline
Old 03-31-2014, 11:29 AM
  #7596
Schelle has a spring kit that will fit the B5, or you could drill out the avid washer to fit the b5 topshaft and use the triad spring.
Old 03-31-2014, 11:34 AM
  #7597
Jake S's Avatar
Trader Rating: 67 (93%+)
Originally Posted by Bob Barry
I've had the front hexs. Just not the axles.
other way around for me, i got the axles in my bag, but no hexes lol
Jake S is offline
Old 03-31-2014, 11:37 AM
  #7598
rigor's Avatar
Originally Posted by thecman26
FYI: If anybody else is in search of the front clamping hexes, Nitrohouse has them in stock, i don't know how but they do!
http://www.nitrohouse.com/Front-Clam...5_p_16643.html
Wow! This place has cheap prices like another online shop in my county... but this one is just 7 miles down the (same) street from my house and also offers local pickup
Thanks for the shop tip
rigor is offline
Old 03-31-2014, 11:39 AM
  #7599
Whats different between schelle and avid??
Old 03-31-2014, 11:44 AM
  #7600
The schelle spur gears are molded out of a different material and are quieter. I am not sure how long avid will continue to sell the triad. Kurt (the guy who designed the Triad) just started Schelle and owns the rights to those designs.
Old 03-31-2014, 11:56 AM
  #7601
Jordan Anderson's Avatar
I heard someone locally actually got a B5M kit late last week.
Anyone else got their B5M yet?
Jordan Anderson is offline
Old 03-31-2014, 12:04 PM
  #7602
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Looks like the B4 ones. How are those supposed to work on the new axles or do you need different ones?
Logi Maker is offline
Old 03-31-2014, 12:14 PM
  #7603
Trader Rating: 165 (100%+)
Ok. I'm with you so far. Part number 91400 includes the 2mm shim. What do you use for 1mm if you want to run 3mm trailing axles?
Chris Gierse is offline
Old 03-31-2014, 12:16 PM
  #7604
2x 1mm shims. Shim the block 1mm on each side.
Old 03-31-2014, 12:27 PM
  #7605
Thanks Matt. Do you have a part number for the 1mm shims?
