T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 03-07-2011, 11:15 AM
  #7201
dag32's Avatar
Trader Rating: 112 (100%+)
When installing the Center Pulley Shaft shown in picture. Which side the little tab go on, motor or battery? Or does it even matter?
dag32 is offline
Old 03-07-2011, 11:27 AM
  #7202
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have always put it on the motor side, and use a small screw driver to hold the tab in place while making the screw tight, you can leave the other screw out, or in loose to prevent tweak.
MikeXray is offline
Old 03-07-2011, 12:05 PM
  #7203
Originally Posted by Adam Howe
Hi,
Yokomo gear diff front and rear, sounds interesting.
What advantages did you see from running spool in the front and normal top diff in the rear on asphalt?
Adam Howe
Tried dual-gear diffs on carpet a while back Adam, it wanted to keep steering coming out of the corner, but other than that, it felt ok.. was slower than a spool though.
chris_dono is offline
Old 03-07-2011, 01:25 PM
  #7204
Originally Posted by *SBH*
Hi there
I have installed the Yokomo diff both front and rear with original aksles = 44,5mm rear and 46mm front, without any problems. I use 1000cst oil rear and 300000 cst oil front. The car is awesome.
Good luck
Thanks to all for all the advice. it appears that everyone is going towards gear diffs for MOD racing here in Australia. The extra power from the current brushless systems puts so much load on the ball diffs and normally need rebulid after 2 runs.
Cheers George
Novice MS is offline
Old 03-07-2011, 01:29 PM
  #7205
Default measuring droop
Just a question on measuring droop. On the front I measure under the arms under the C Hub pin. But not nsure about the correct place to measure droop on the rear. How does everyong measure rear droop at what location? Thanks George
Old 03-07-2011, 01:32 PM
  #7206
Originally Posted by Hugh Jazz
George i ahve a few spare yoke blades. I will bring them with me when i come up to get my chair off Trev
Thanks Dan that would be good to have some spares.
Old 03-07-2011, 03:04 PM
  #7207
stiltskin's Avatar
Trader Rating: 103 (100%+)
Under the hoop.
stiltskin is offline
Old 03-07-2011, 08:58 PM
  #7208
Trader Rating: 17 (100%+)
I will lift the rear of the car and measure how high it will lift before the rear wheels leave the ground using a ride height gauge. Usually try to keep it around 2mm. Same for the front.
Mr.A Morris is offline
Old 03-07-2011, 11:26 PM
  #7209
*SBH*'s Avatar
Hi,
Adam Howe
Hi Adam
The car is just faster with gear diff compared to ball diff, You can adjust it more evenly due to different thickness of oil, and You dont have to spend time on rebuilding diffs. I have tested several times with spool or geardiff in front, and if You use thick oil, its always faster and easier to drive with geardiff. With uPro You have to use some very thick grease something like 700000 - 1000000cst, but with Yokomo, Spec-r or similar big diffs, use 300000 as the internal gearration in the diff is different.
I hope this helped.
*SBH* is offline
Old 03-07-2011, 11:56 PM
  #7210
Travis S's Avatar
Trader Rating: 46 (100%+)
Anyone know what servo was ment to be used in this car with no mods or shims?
Travis S is offline
Old 03-08-2011, 02:30 AM
  #7211
*SBH*'s Avatar
Bluebird have some nice low servos that fits and works perfectly
I use BMS-390DMH
*SBH* is offline
Old 03-08-2011, 12:19 PM
  #7212
wayne breault's Avatar
Default U pro gear diff
I just bought ProTon U Pro gear diff. Going to run it in the rear, on medium traction asphalt. Should I do anything to it before putting it in or should I put it in and just run it as it is? Would be greatfull for any help
wayne breault is offline
Old 03-08-2011, 01:17 PM
  #7213
stiltskin's Avatar
You shouldn't have any issues running it straight out of the package. It is preassembled with 20k oil which works fine in the back.
Old 03-08-2011, 04:23 PM
  #7214
drcw197's Avatar
I use the the savox 1257 and fits perfect
drcw197 is offline
Old 03-11-2011, 10:21 PM
  #7215
Professor's Avatar
Trader Rating: 12 (100%+)
Default caster blocks
can any of the t.o.p usa guys (or anyone else for that matter) tell me if top are going to bring out 6deg caster blocks as an option part as i see a few people in the us are using them (xray ones i mean) & they are now being used her in oz as well & i would also like to use them but i dont particularly want to buy xray parts
thanks
graham
Professor is offline
