T.O.P. Racing "Scythe" 1/10 EP Touring Car
#616
hi just a quick question may be buying this car so what is the ups and downs spares etc i should look at carrying spare.
And whats best for 19t and stock 27t rubber carpet/tarmac, a spool or diff?
#617
O and what sort of spur/pinion range would i have to carry in either 48 or 64
#618
double post.
#619
If you getting a kit the extras id suggest is a spool which is a must have in my book, a spare set of belts as well as spurs.(102 spur std)
I much prefer the std Scythe kit compared to the ally kit for asphalt.
For the plastic base kit a set of bulkhead top peices for the shock mounts.
a few toe plates for tuning.
The suspension parts ie a-arms uprights etc.. are all cyclone/Pro4 parts so should be very easy to get.
27T stock gearing is in the 28T - 35T range with 64 pitch.
As for shock pistons the std ones are great and for better feel i have drilled the holes to 1.2mm and use 45wt GS oil.
Std springs are working well for our tight asphalt track but TOP has a a neat spring kit you can by with a selection of 12 pairs alternative is a TeamMagic spring kit.
So far over the last 8 months of running the Scythe i have rebuilt a diff and replaced the bulk head tops once after some exhuberant driving.Other than that car has been very durable and reliable.
This Saturday im running it in a 6 hour enduro so will see how she takes that abuse.
#620
Is there any build tips or issues that you can point out when building an 07 or 08 model?
What make and what type of springs are best/most used on this car?
Does anyone have a set up that is good on carpet med traction rubber tyres?
What would be advised when running a 19 turn motor and a 27 turn motor, spool diff etc?
Cheers
Cheers
#621
Have you downloaded these :
Scythe Instruction Manual (Rev. 2)
http://www.top-racing.jp/UploadFile/...2125634591.pdf
Scythe Assembling Addendum
http://www.top-racing.jp/UploadFile/200632211214422.pdf
Car goes together well and i would suggest you get some shim sets to take out slop on the wheels and hinge pins.
#622
For 27T and 19T i would recoomend you get a spool as a option for tuning at your local track, i prefer it to the oneway.
For springs try the std ones first they are not bad at all for that matter try the std setup and take it from there. I was surprised how close the std setup was to how i like.
#623
hey guys i just thought id let you all know i will be running the scythe as soon as i get it here so any tips would be appreciated thanks later jason
#624
Great pick up TOP.....Now lets just see if Jason can get a Win at snowbird...
#625
Not if i go but you and ej can fight for second!
#628
I know i should just get high so im not nervous.
