Team Losi JRXS Type-R >
Like Tree52Likes
Old 10-28-2008, 03:03 PM
  #8326
TJames987's Avatar
Trader Rating: 11 (92%+)
Hi I have the type R and run on high bite asphalt (colesium frederick md) and I'm looking for a setup that will work with the front One way without breaking the rear end out, appreciate any tips.
TJames987 is online now
Old 10-28-2008, 06:08 PM
  #8327
Mike Haynes's Avatar
Go for one of the carpet rubber one way setups, they will be a great starter for the C.
Mike Haynes is offline
Old 10-28-2008, 06:42 PM
  #8328
jrr102486's Avatar
is there anything im doing wrong?
heres my basic setup:
novak 13.5 with xbr speedo
front oneway
prs adapter with kimbrough 116/42
7 grams over min sedan weight of 1525
muchmore sweep 32's
on my track my fastest time is 10.1 sec. the xrays and associateds are running almost a full second faster.
any ideas?
jrr102486 is offline
Old 10-28-2008, 07:53 PM
  #8329
RedRocketRacing's Avatar
front oneway
muchmore sweep 32's
any ideas?
I am not know much about that speedo, but does it have the forward drive and a GTB or a higher end speedo?
RedRocket
RedRocketRacing is offline
Old 10-28-2008, 08:01 PM
  #8330
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
front oneway
muchmore sweep 32's
any ideas?
Do you clean your tires after every run and then sauce them?
is the compound choice too hard? (never ran sweep tires...)
Are you sprung too stiff/soft?
What is roll center at?
Have you driven on the track much?
is it the car, or the driver?
We need more details
a_main_attendee is offline
Old 10-28-2008, 08:11 PM
  #8331
Company Representative
SweepRacingUSA's Avatar
double post
SweepRacingUSA is offline
Old 10-28-2008, 08:12 PM
  #8332
front oneway
muchmore sweep 32's
any ideas?
you wrote your "equipments" not an "setup"
I think that is your problem
you don't know what your setup is.
Old 10-28-2008, 08:31 PM
  #8333
jrr102486's Avatar
im running mikey dibbs setup from the novak race. its the best setup that i have found. since i work at the place im on the track quite a bit. there is another guy running sweeps and hes running an xray at the full second faster. there is one other guy that works with me running a type r with a losi 13.5 and is the exact same setup and is pulling the same lap times as me.
front
toe-0
ride height-5.5
camber- 1 to 1.5
kick-0
caster- 2
droop- 1 over ride height
front pivot -0
roll -.030 under low
arm-middle
shock -2
steering- 1
spindle- 1
camber link- 1
camber ball stud- silver
arm length- long
one way
pulley 42
diff high
hex width .165 stk
oil 40
piston
56
spring 17.5
rear
toe-3.5
ride-5.5
droop - 1.5 over ride
arm spacing- middle
anti/pro- 0
hub- .5
rear pivot- 2
roll center - .030 under low
shock position- 2/outside
camber- 5a
camber link ball stud- stock
arm length- long
diff- low
oil 30
piston 56
spring 12.5
clean tires after every run. using jack the gripper. not running "jr" link.
and dont assume i dont know my setup. if you have ever taken hunters saftey u know what "assume" means!
Old 10-28-2008, 10:35 PM
  #8334
Got about 3 weeks on both the car and rubber tires in general and I must say I love it. Car is ridiculously good. Also just got to run a Losi 4400mah 30C lipo tonight for the first time and it is as good as my SMC 4000mah lipo. Also love that the pack doesn't rub the pulleys at all with no modifications at all.
Am I just about sold on getting another car for foam? It's getting closer, but still unsure.
JoelV is offline
Old 10-28-2008, 11:59 PM
  #8335
Matt Howard's Avatar
Joel- The car is REALLY good on foams as well, you won't regret it
Matt Howard is offline
Old 10-29-2008, 06:28 AM
  #8336
Yeti35's Avatar
The Type R excels in foams and in the right hands is so stuck.
Yeti35 is offline
Old 10-30-2008, 09:18 PM
  #8337
For those looking for the steel lipo tray. Not sure how many they have, but I emailed before ordering to make sure they had it in stock and they said they did at www.rc-mushroom.com. Not too much of a fan of ordering from Hong Kong, but if it's the only place the thing is available then ok.
JoelV is offline
Old 10-30-2008, 11:48 PM
  #8338
Adam?'s Avatar
Hey guys, a few folks in our club are struggling to get their R's working right on carpet with rubber tires. We're using Jaco Blue as our spec. Anybody mind pointing me to a reasonable setup to get these guys started in the right direction? Nothing too aggressive, if that's an option, the guys are still getting the hang of carpet. Thanks!
Adam? is offline
Old 10-31-2008, 01:02 AM
  #8339
anybody have a good starting point setup for a Jrxs for rubbertire on carpet???
jon Perkins is offline
Old 10-31-2008, 04:25 AM
  #8340
FOXY923's Avatar
Default Battery tray screws
I was just wondering if anybody has tried/been successful in getting the battery tray screws to stay in the battery tray so they can't be lost? I was thinking of using shoe goo to put a bump on the thread right near the head of the screw while the screw was in the tray (hole). It would have to allow the screw to turn and screw all the way in but is this something that could be done? If it could it would save time looking for the screws and may even save a screw or 3.
FOXY923 is offline
