Tamiya TB-Evolution III
#4021
Do you have a Quantum Competition 2 yourself?
#4022
no i have the original quantam but the programs exactly the same layout.
ive seen the instruction for one and are exactly the same setup procedures.
iam hoping to get one though.
have you driven the original quantanm?
comparisons between the two?
#4023
I have the Novak GT7 and the LRP V7.1, however this new Quantum Competition 2 seems to give the BEST PUNCH
#4024
Hi trfracer.
I have the Quantum esc and can't seem to figure out how to load the team factory settings. How do you do this?
Thanks.
Thanks.
Originally posted by trf racer
ok to adjust the punch intial brake etc is a bit more complicated.
hold the mode button down then you should get a flashing green light.this is the punch control
you can check the set value[1-5] by counting the red led flashes [1 flash equals value 1,2 flashes equals value 2 etc.]
you adjust values by pressing setup
press mode button again and this will bethe intial brake again we havesetting 1-5.
press mode again and we have automatic brakes set up [drag brakes]
with 1-5 settings.
on the punch control 1=smooth 5=mega punch
on the intial brake 1=linear 5=progresive
on the drag brakes 0=off 5=strong
default setting is
punch=2
intial brake =2
drag brake=0
hope this helps.
with 1-5 settings.
default setting is
punch=2
intial brake =2
drag brake=0
hope this helps.
#4025
@McLaren
Here´s the link for the download for the Quantum Competition instruction. This should be the same for the Competition 2.
http://www.lrp-electronic.de/e/downl...oad.asp?id=459
#4026
Thanks a lot ... I got the setup instructions for the LRP QC 2!
By moving the front shocks to a more upright position, it will increase dampening, yes? Will this slow down the reaction going into a corner?
#4027
Randman dude
i was just ordering ( trying to ) the tc3 gears but i cant find the code for the delrin type. i can only find the normal type.
can you help me please
thanks
and what shimms did u use?
thanks alot
thanks
thanks alot
#4030
ok im more lost what i meant is which shimms can i use for a diff in the front and back, how many would i need, what sizes.
I know im asking alot and im prolly annoying you! but i dont wanan get it wrong... too much money!!
#4032
Randman,
missed your article... Can you please post the link to the page where you posted it...
steevo
steevo
#4033
Originally posted by Randman
It's all finished Check it out and spread the word! http://members.cox.net/randy316/
#4035
Yea Dave just ordered some. We are actually going to try and go a step further and make an easy fix for the car. I'll let you know how it turns out. I told Dave there might be a market for a simple kit to totally eliminate the ring gear problems, but he isn't so sure. I know I would buy a kit for a reasonable price if I were sure it would fix the problem... hehe.
