Like Tree639Likes
Tamiya TA08 Pro
Old 07-22-2022, 07:42 AM
  #646
Core Creations's Avatar
Trader Rating: 108 (100%+)
I’ve had the 08 since it was first released and got the main spares that were available on release. I have yet to see chassis and some of the kit specific spares come in stock in the US. I’m just surprised the manufacturing process is that far behind still. I won’t race my car if I don’t have a spare for likely breakages. In addition those same parts haven’t had aluminum hop ups or add ons to upgrade strength and reliability. I think the fact we haven’t seen an upper deck for use on high grip surfaces is pretty lame…this car has the potential to be a beast…but if you are running TCS spec…it’s a dog on carpet because of the flex.
I started worrying some when I saw the one way and ball diff as a hop up early on. It kind of seems that this car hasnt been designed with medium or high grip surfaces in mind at all catering to more the low grip carpet or asphalt.
Originally Posted by Raman
True that they’re announcing new cars but those cars and their respective spare parts become available 5-6 months out. Eg 420X was announced beginning of the year. Kit just arrived at tower, not much stock of spares.
Spares for older chassis are also very scarce. When they finally arrive are gone in an instant.
Core Creations is offline
Old 07-22-2022, 07:53 AM
  #647
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Core Creations
Yeah that could be.
Both Tamiya and Kyosho are still having serious delays at port of long beach.. this is due to the pandemic.
This TA08 doesn’t share a lot of parts with other chassis so it makes things worse. The XV02 that just came out shares most it’s suspension parts with the XV01.. so the consumables are available.
As for TamiyaUSA, they’ve been terribly quiet on all fronts. They used to respond to an email within a week, now it’s radio silence
Raman is offline
Old 07-22-2022, 03:32 PM
  #648
Interesting alternative to the aftermarket top decks, similar to what used to be done to the TA05 with a pair of long turnbuckles connecting the front and rear bulkheads: https://www.thercracer.com/2022/07/t...k-mod.html?m=0
BuggyFan21 is offline
Old 07-22-2022, 06:01 PM
  #649
Raman's Avatar
I run that top deck. Helps a lot on black carpet
Raman is offline
Old 07-24-2022, 07:56 AM
  #650
Originally Posted by Captain Howdy
This seems to be a common breaking point, hit a pipe and tore the ball end right out. Opinions on best fix for this? Ordered a new chassis but will be a while till it gets here.
if this wasn’t mentioned yet. Drill through the entire chassis. Counter sink the bottom of the chassis and use a screw
Captain Howdy likes this.
Juan Aveytia is offline
Old 07-24-2022, 08:53 AM
  #651
Raman's Avatar
There is not much chassis to countersink on the bottom. The hole is right on the edge of that centre channel. 5x8 stud is best bet in my opinion
jgil089 likes this.
Raman is offline
Old 07-24-2022, 07:08 PM
  #652
Old 08-16-2022, 07:16 AM
  #653
I picked up a TA08 and have some very dumb questions -
1. How tight should the belts be? On the factory recommended settings they seem super loose, but I'm assuming for 21.5 or lower powered classes it's probably fine? Also is there any way to adjust the tension other than pulling the suspension and arms and bulkhead off each time?
2. Is it a bad idea to run some kind of spacer to use my shorty packs? I figure I can always add lead weight to balance it out but it's what I have right now and don't want to buy more batteries.
Raguvian is offline
Old 08-16-2022, 10:33 AM
  #654
Default Lower Deck
.lower deck where can one person find this hidden treasure?
is it me or does this chassis break easy?
does any one make or what other chassis plate couli use/ mod to make this work?
hotrod306 is offline
Old 08-17-2022, 04:04 PM
  #655
Herc Driver's Avatar
I like my M08…for for ease and durability give me my TA04 any day
Herc Driver is offline
Old 08-18-2022, 05:18 AM
  #656
simple's Avatar
.....huh?
simple is offline
Old 08-18-2022, 07:38 AM
  #657
Raman's Avatar
Originally Posted by simple
.....huh?
simple likes this.
Raman is offline
Old 08-18-2022, 10:11 AM
  #658
simple's Avatar
....meanwhile, Just finished my second TA08...as an alternative to my Xray's, I really like these plastic weapons.
simple is offline
Old 08-18-2022, 10:26 AM
  #659
Raman's Avatar
Looking good. Mine unfortunately has become a shelf queen.. I’m a man without an RC racetrack at present 😔
Raman is offline
Old 08-18-2022, 12:51 PM
  #660
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Come out to TCS finals with Juju.
Dan is offline
