1/8th Nitro On-Road - Edam Razor
#273
When i had this Problem sometimes with an older Frontbumper, i made following:
I take three tires on table, puting car on it. one tyre under the rearend of chasis, and even one under the left and right end of the bumper. Than i heat it with a hairdryer, near the side-end of Chasis. The bumper will lift his ends. I do it carefully, until the sideends of the Bumber ar a little higher, than i stop heating.
With this bumper i drive since a year.
At my car, only the side-ends of bumper will come down, never the middle part.
i hope, it will help you.
If not, place a rod between bodymount and End of the Bumper on the sides
Leichtmetall
Leichtmetall
#274
A rumor
I was told by a racing mate that Edam razor has a number of interchangeable parts with the MRX4. I have an old MRX4 lying in the corner, stopped use due to lack of available parts after a big crash, just wanted to know, if this is actually true and if so, would it be possible to rebuild from Edam spare parts? Parts in questions is mainly right side upper arm and rear bulkhead
Thanks, Jon
Thanks, Jon
#276
Razor
Hi I'm new here, are you guys still running the Razor? Cheers
#277
#279
Cheers guys.
#280
still a good car for the club etc... hope they work on a update... afforfable racer for most..
#281
Parts support still OK with this Razor 2?
#283
Has anyone fitted a reverse clutch to this car? i.e. Capricorn, Xray, etc.? Thanks
#285
If the dimensions of the clutch is the same as the one on the Protech XR8 (Edam production) I had you can run a complete Mugen clutch.
