whats the differance between RDX and the RDXPHIL?? >
Old 05-02-2008, 09:40 AM
Phoenix82's Avatar
Default whats the differance between RDX and the RDXPHIL??
WHats the differance? is there a service pack to upgrade the chassis?
Nick
Phoenix82 is offline
Old 05-02-2008, 09:52 AM
edseb's Avatar
Nick
No, they have many differences. The general geometry is very similar, but the bulkheads have been moved in to be narrower, this changes the mounting holes in the towers and the new towers are different. Arms, upper deck, steering, lower deck, bulkheads, rear hubs, sway bars, etc. are all different. Only some small stuff can be used from the older RDX car- ball studs, steering knuckles, hinge pins, roll center hinge pin blocks, screws, etc. There is not enough similarities to have a service pack.
edseb is offline
Old 05-02-2008, 09:56 AM
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Handling wise, the two cars are very similar, due to sharing many of the suspension components. But as Carl said, almost all of the chassis and drivetrain components are different and making a service pack would be pointless because it would contain 80% of a new car. The changes give the Phi more adjustments and is MUCH easier to work on and adjust.
JamesArluck is offline
Old 05-02-2008, 11:17 AM
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
like comparing a JRXS to a JRXS Type-R...
Syber Serulean is offline
Old 05-02-2008, 06:50 PM
Trader Rating: 16 (94%+)
Sorta Kinda in a Way, BUT then again, Not Really.
The PHI is a more competitive car, where every little tweak here and there makes a difference.
kn7671 is offline
Old 05-03-2008, 02:20 AM
The major difference is all the things you wanted to make- servicing the RDX the RDXPHI has.When you break something on the Phi you can fix it a heck of alot quicker and easier.They are both great cars.
BullFrog is offline
