E-revo Battery Help >
E-revo Battery Help
E-revo Battery Help
Old 02-02-2009, 10:07 AM
Default E-revo Battery Help
Im running a e-revo with a Feigao 8xl with a mamba monster max esc, and currently 2x 2cell 3800mah team orion batt packs, and they run for about 8-10 mins. Can anyone sudjest any lipo packs that would give me longer run time, like double? And a link if posible. Thank you
bob3104558 is offline
Old 02-02-2009, 10:35 AM
liv2ride41's Avatar
Default Maxx amps
I run the Maxx amps 6400 2s packs in my brushless E-Revo. I have the Losi 2100kv monster motor and a Monster Maxx esc and can usually get 35 to 40 min of run time on the race track. Just look up Maxxamps.com.
liv2ride41 is offline
Old 02-02-2009, 02:32 PM
with the max amp batteries do you have to balance them? with my team orion batts i was told i didnt have to
Old 02-02-2009, 07:05 PM
Trader Rating: 21 (100%+)
Your Orion lipos are made from Kokam cells. They are high quality cells that are matched when assembled - thats the reason you don't have to balance them. I wouldn't expect the same from MA lipos, you'll need to balance them.
Duster_360 is offline
Old 02-03-2009, 09:42 AM
ok, which balancer should i buy? do i balance it every time i charge it? I have a Ice charger, but i dont think it balances
Old 02-03-2009, 10:05 AM
Correct, Ice does not have a balancer. This is a good one, easy to use that works well -
http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML
If you have a voltmeter, you can read the individual cell voltage via the balance tap. The Orion lipo - charge when it shows a diff in cell voltages, maybe every 7 to 10 times?
Lipos like Maxamps, I'd charge every time. Again, its how quickly the cells start to show diff voltages. I use a Hyperion 0610iNet charger with a built-in balancer and just balance every time.
Old 02-04-2009, 01:00 PM
what about a integy 5800mah batt? any good?
Old 02-04-2009, 06:06 PM
I've never owned a batt by Integy, but everything else by them I've owned was poor quality. If its cheap compared to same capacity elsewhere, I would be concerned about the quality of the lipo cells.
Personally, I stick with name brands like Orion, PolyQuest, Flightpower, TrakPower, NeuEnergy, Hyperion. Its worth it in the long run.
HTML code is On
