rc10t4 factory team kit (NIB)
Associated RC10T4 Factory Team Truck Kit (NIB) for sell $220.00.
FEATURES: New longer MIP CVD Dog Bones and Axles
Lower motor mounting position
Genuine Kimbrough 48P 87T spur gear included
Hard anodized threaded aluminum shock bodies
High traction racing compound Pro-Line Hole Shot Tires
Plenty of chassis room to accomodate most electronics
All new molded composite low CG chassis
Adjustable battery position, new style hold down strap
Rugged blue anodized titanium turnbuckles
Built in servo saver
Angled bellcrank "Co-Planar" steering
Fully adjustable caster, camber, and toe-in
Ribbed racing compound Pro-Line The Edge Tires
Vertical ballstud adjustment for the front and rear
New 2.6:1 laydown stealth tranny w/higher torque capacity
differential
Trailing front axle or optional inline steering blocks
Front shocks mounted behind front shock tower w/captured hinge pins
Forward swept front end design for maximum ground clearance
High torque capacity, double sided slipper for finer adjustment
Impact resistant rear motor guard and body mounts
Lower motor, battery, shock and body mounts for lower CG
Full set of sealed ball bearings
Sport truck racing body
"Factory Team" sticker
INCLUDES: One RC10T4 rolling chassis, 87T spur gear, high traction front and
rear tires, MIP CVD's, molded carbon chassis, Stealth tranny,
extra long suspension arms, anodized aluminum shocks, sport truck
body, white dish wheels, instructions, decals
REQUIRES: 2-Channel Radio with one high torque steering servo
6 cell battery pack (stick configuration)
6-7 cell battery charger, timed or peak
Electronic speed control
540 size motor
48P pinion gear
Miscellaneous building and field equipment
differential
540 size motor
48P pinion gear
