Tamiya F104 Version 2
#1502
One last thing on the plates. Clean them with motorspray first to remove any oil or corrosion inhibitor.
#1505
I've only been using a speedpassion V3 21.5T motor with a 93T spur/32T pinion combo on a large (30mx12m) indoor carpet track and the motor temps never get above 55°C after a long 10 or 15 minutes driving.
#1509
Pretty sure I remember reading the exotek wheels where designed with this in mind and make the the f104 186mm wide so you can add shims and/or camber and still roll through a 190mm tech box.
#1510
Hey guys I have an issue with the rear inside tire lifting on corners. I have played with changing the tube lube from 10-20-30-50k with soft medium and hard side spring combinations and it did nothing to fix the problem. I am running on high grip carpet on pardus tires. Any ideas?
Is anyone else have a better solution to this?
#1511
I experience this alot with pardus tires on carpet. Only solution I found was to use extremely thick lube in the diff. Downside is that the car gets loose under acceleration after a short time during a run. I have tried the full range of springs and tube lube, as well as changing rear track width.
#1515
idbdoug
