Ceramic Bearing VS Normal Bearing
#16
Originally Posted by MRX_joe21
This type of ceramic REAR bearing enables a very high rotation speed. The low density of the ceramic balls makes the crankschaft’s rotation easier at high RPM. The ceramic bearing’s longevity is also widely superior to a normal bearing.
i have only used ceramics on chassis bearings. they work well in that application.
#17
Have two RB C-5 modifieds that are a year old with quite a bit of time on them and the hybrid ceramic rear bearings feel as good as new - very impressive. Ordered some Boca ones when they first became available a couple of years ago and they felt so radically different in clearance from standard Nova units that I never even installed them.
Rick Davis
Rick Davis
#18
Originally Posted by sedanaddict
can you talk for yourself or can you just quote some advertisement every time you post? do you have any personal experience or just ad copy???
I have Acer ceramics in my JP (.21) are they any better? I am not sure, they are as good as standard, but I havent noticed any noticable performance gain. I am hoping the longevity factor makes them worth the coin. I have also used acer ceramics in my NTC3 & they were awsome, I could always win the how far can your car roll on its own contest. Didnt make me any faster on the track but. I need some bearings that are magnetised to follow the perfect line around the track
#19
jmf
#20
well since we are on the subject of ceramic motor bearings here, i can assure you the ones from boca are no where near as good as the orignal ones used from novarossi or rb.
the ball size from boca are extremely small compared to the novarossi ones and i have had them personally crack on me and destroy a brand new piston and sleeve set rody had just installed in one of my 1005-rc motors.
DO NOT USE BOCA CERAMIC MOTOR BEARINGS, i have never in 2 years of having dealt with them gottenthem to admit that the bearings are junk. go ahead and use them in a 650.00 motor if you want, but dont try and cry or complain when one of the balls cracks under load
for whatever reason, novarossi based ballbearings are very tough compared to the ceramics
just my 2 cents
just my 2 cents
#21
yes good call about the boca's, the balls are most definitly smaller than the rb's/nova
#22
Originally Posted by soc123_au
Beat me to it
Just want to share a little of what I think.
I worked a little bit selling ceramic balls for bearings about 5 years back. Balls are mostly Silicon Nitride- one of the hardest(meaning brittle, less tough than steel). What we do is pack the powder and sinter(heat to about 1800deg C if I recall correctly) to fuse them and then polish them into balls. The races have to be steel(softer than the ceramic balls) otherwise all will break into pieces. I think this has not change much. Yes they do have slightly better coeficcient of friction than steel balls and last longer(10x because ceramic is harder) in high speed application like dental drills -40000-60000rpm which will eat up steel balls very quickly.
So where there is impact and shock, steel balls(softer than ceramic and tougher) might take the abuse better. My FX-21-03 comes with ceramic bearings, break in properly, ran 7 tanks after that and there was some play on the crank. If I continue, it might be a disaster. I've since changed to standard bearings and has been working well. I have also not notice any performance difference between ceramic and steel bearings.
So I would still think quality steel bearings makes a decent deal here in our sport and will not rob you of competitive edge against ceramic ones - save the money for something else unless one has a fat budget. Sorry if I offend anyone.
#23
I build our bearings from scratch using only the best S2 grade cerbec Si02 balls. It makes a difference over a stock bearing. This is the only way to control what goes into the bearing and to insure it is abec spec'd correctly. your right the bocas are over priced and the abec spec is to sloppy. Currently the only bearing I focus on is the big one and haved used full ceramic hybrid and ceramic,carbide ball hybrids. Ceramic/carbide works the best as when using ceramic balls only the ball bearing tends to load up the races. when you compliment it with an every other steel ball the steel ball keeps the races scrubbed.
yes they are worth it if done right.
#25
Like most of the posters my experience with both Boca and Acer has been mixed. Sure some of the Boca have been great but some have been a real waste. especially given their price. I mean, $8 a bearing and some have died pretty quick. I've bought a few sets from Acer before and was happy with the results but can't buy gold for the price of tin. My experience is they don't last as long as a racer would like i.e. forever. The shields tend to come off a bit too easily. But then again, if you want to try ceramic I'd recommend Acer. $90 gets you a set plus shipping. Some guys charge $200 and up for a similar set and the bearings don't seem to last any longer.
#26
Originally Posted by TitaniumR
Hi SOC and all,
