TT-01 Forum
#436
hey, I'd like to be able to drift my TT-01 aswell
mine is stock with ball bearings, I just made it but already thinking of hop-ups... I heard my tires wear fast so I guess I'll buy new ones. I couldn't find Yokomo Single Ring tires... I just found Yokomo drift tires, is that the same? are there other hop ups that is a good idea for drifting?
Will these work?
I was just watching this video on youtube and the guy is drifting pretty well, he says it's a stock tt-01, I guess the surface was pretty smoooth... I wanna be able to drift on pavement :/
Will these work?
#437
Will these work?
Will these work?
basically, its a combination of plastic ring with rubber compund. not too sure whether that high grip radial tires will work as it looks like too much grip.
good luck!
#438
ABS Is definitely the cheapest way to go. Although you'll need to cut it yourself unless you buy some ABS tires off ebay, they last forever.
Sushi drift tires sells his through ebay. He rounds the edges too, which helps in the look/uniformity of the tire. They go for pretty cheap too
Those Yokomo tires I hear are very good, but the rings wear out. I wouldn't let that discourage you though, because they should drift really well.
#439
with these sushi drift ABS tires, can I still drive the car normally or will it skid out all the time?? just wondering
those Yokomo tires look tempting too, because if they drift much better, I won't mind spending the extra cash..
one more question, what's a good pinnion/spur to get for drifting? I would guess that I'd still want good acceleration but higher top speed. someone suggested 25/55, but that was for top speed I think..
#440
hey thanks mooshu, those sushi drift tires here look nice... they come with 3 sets too for so cheap! buy you say they'll last long so, I guess I might not need 3 sets
happy drifting...
#441
set up
hi,
what kind of set up would you guys suggest (ie, shocks, gearing, tires, springs, etc)? i am running on a small track with tight corners and a somewhat short backstretch and i am running the stock motor the tt-01 came with. i also have coming alum shaft, bb's and heat sink. any help is appreciated. thanks
jake
jake
#442
Hi Evad, I don't know much about peak gearing, but I would suggest gearing a little lower than the 55:25 gearing everyone suggests for an all around gearing. If your track has many twists and turns, then I would gear lower, since the TT-01 is hard enough to turn as is... What kind of class is it?
You're going to want your differential as open as possible for those turns, since I have heard and noticed that the TT-01's turning radius isn't that great. If you can afford it, get some lowered springs that are around 0.9 inches and stiff. If you're on a track you're going to need the responsiveness of stiff springs, and the lower stance will stick the weight of the car where you want it.
Someone should give you a suggestion about oil filled dampers, since I have no experience in that realm either. But I believe light oil is what you want for stiffer springs, and heavier oil for soft springs.
Tires: what kind of track is it? Carpet, pavement, etc? All around though foams should be your best bet. If you're really serious about trying to win at this track, get a very high grip but low life foam.
There are tons of things you can buy for the car to make it a racing machine. Just read up in this forum about tuning, I learned a lot that way. And also, play with your car.
If you can, go to the track and experiment. If you don't like something about the handling, write it down. For Example, if you're getting oversteer out of the corner, try softening springs in the back. If you feel your turning radius could be better, you could fiddle around with toe out in the front (since that's the only thing you can adjust on this thing without buying extra arms etc.
If you bring your problems here, I am sure lots of people can help you. I feel like I have a good grasp of the physics of it all, but I could be wrong. Anyone feel free to correct any and all of the mistakes above if any.
#443
where to buy pinion/spur gears?
hey guys... I have looked but I can't find where to buy any TT01 spurs/pinions!!
Am I blind? What should I be searching for? "TT01 tuned gears"? "TT01 spurs pinions"?
Does anyone know a website that sells 25T/55T pinion/spurs or other?
Thank you
PS: can I still drive my car fairly normally with ABS drift tires (Sushi Drift) on? Or will it drift every time I turn?
Thank you
#444
Thank you
Thank you
with ABS you car traction is very low. it will be difficult to turn/drive normally unless u are driving very slowly. u ll notice rear traction is really poor with abs give it a try...
#445
try this: http://www.tamiyausa.com/product/rcp...chassis_id=A05
hmm I see, so I guess I'll want a different set of rims to change tires... those Yokomo rings come with rims correct? Are they the same as ABS, ie. can't drive normally with them on?
trying to decide between the two, sushi drift or yokomo
thanks again!
#446
that's perfect doriftu !
thanks again!
thanks again!
in the end it your call either with sushi or yokes... cheers
#447
those yokes single ring are sold either with rims or with the tires alone. u have to check it out. as mentioned they are combination of plastic and rubber. if u want to drive normally ie need traction, u ll need to camber the tires a lot to have more contact with the rubber. if u want less traction put to 0deg camber so that the plastic ring is contacting the surface. once u got the tires it will be clearer...
now as for those spurs/pinions, I can't buy them from Tamiya USA (I'm in Canada)... anyone have more suggestions on where to get them? Thank you!
#449
I will give an intense review of it, no doubt
I'm buying:
- $50 duratrax piranha charger,
- $40 intellect 4200mAh nimh batt (piranha will charge this right?)
- $4 55T spur (can only find the single one online at tower)
- ~$9 24/25T pinion at LHS
- ~$6 alum prop at LHS
- $? rims at LHS (for drift tires... good idea?)
- $? basher body... not sure, maybe later? (looking for a cheap one, I love my bmw body! it's the same car as the one I totalled )
- ~$5 ceramic grease at LHS
hmm what else...
#450
I'm buying:
hmm what else...
I'm buying:
hmm what else...
well if u got extra cash, splash on a nice set of rims... u can go bling! hehe...
which BMW body u using? the newest one? E90? im looking for a E30 (the squarish 3 series) if u know which beemer im referring to...
oh u can get the steering linkages too... aluminum. or the CF upper deck... the list goes on as long as u have a deep pocket...
happy sliding sideways!!!
