go go juice comm drops >
Old 07-08-2004, 02:32 PM
  #16
Neil Rabara's Avatar
Originally posted by rtypec
For what it's worth: the motors that won GT1 and F201 classes at the recent TCS races held in Aliso Viejo were both tuned using gogo juice for comm drops.
That's what he was using? I thought it was just oil.
Neil Rabara is offline
Old 07-08-2004, 09:35 PM
  #17
mcc-bri's Avatar
if you put on 2 much gogo juice you will discolor the com, if you just use a drop or 2 it should work well
mcc-bri is offline
Old 07-08-2004, 11:16 PM
  #18
Dis-coloring of the comm is due to heat, not the comm drops. Are you saying that the comm drops increases heat in the motor?
Old 07-09-2004, 11:01 AM
  #19
mcc-bri's Avatar
i found the com drops heated up the com if you pit to much on
mcc-bri is offline
Old 04-26-2011, 08:36 AM
  #20
RsageD's Avatar
sorry to bring this back up... i am new to this and recently purchased GOGO Juice. Do u just put a drop on ur bearings? what else is it good for? BTW, what is "Comm"?
Thanks and soory for the noob questions. Im running ezrun 5.5t and all bearings are stock TF5.
RsageD is offline
Old 04-26-2011, 08:48 AM
  #21
wingracer's Avatar
Trader Rating: 24 (100%+)
You don't use comm drops on brushless motors.
The "comm" is short for commutator. That's the copper cylinder with three cuts in it that the brushes ride on in a brushed motor. Comm drops are put on the comm to get a small performance edge for a few laps. Brushless motors don't have comms or brushes so they don't use comm drops.
wingracer is offline
Old 04-27-2011, 06:37 AM
  #22
RsageD's Avatar
Yup! just read up about the difference. Thanks! So using the bearing ones can be used for the bearings all round?
RsageD is offline
Old 04-27-2011, 09:54 AM
  #23
heretic's Avatar
Funniest quote EVER !
heretic is offline
