3 Racing Sakura D3 CS Drift >
Like Tree2Likes
Old 01-27-2013, 10:20 PM
  #1291
Angry_Arowana's Avatar
Originally Posted by eunique
I have had my D3 since it first got released...I'm only on my 2nd belt...and I try to practice as much as I can. I use the 3racing belt....running an 8.5T motor, so it's plenty powerful...and I use 3racing alumium 13T pulley and Zero S Front One Way without the spacer.
Also, check to make sure nothing is binding and that both sides are equally tensioned by the position of the bearing adaptors and not tweaked
Looks like I'm the only one here having the problem,I'll check again when I get my belts arrived from rcmart.
Pickle,I'm using the d3 one way.
Angry_Arowana is offline
Old 01-27-2013, 11:05 PM
  #1292
Originally Posted by Cloaked
3 battery packs in, and I still cant get the hang of this thing.
Too heavy on the throttle I think.
probably...look at my post regarding the finesse drifting
eunique is offline
Old 01-27-2013, 11:50 PM
  #1293
pickled's Avatar
I think you should strip the front down have a good look at the orientation of the bearing covers and play with them in the lower bulk head till you know which way the they tension 100% then put it all back together and tension it so it's not tight but not real loose either.
are you using brake on the ESC? or crawler mode? try turning the brake force down and no initial braking. you don't need brakes anyway
pickled is offline
Old 01-28-2013, 02:56 AM
  #1294
Cloaked's Avatar
Trader Rating: 15 (100%+)
So I put the stock tyres back on instead of the softer Spice Tyres, made so much of a difference!
Biggest issue now is the centre belt is getting real loose, even with the belt tensioner.
Cloaked is offline
Old 01-28-2013, 10:14 AM
  #1295
One other thing...check your CVDs...they don't come assembled properly. Check that it's not binding...disassemble them. Grind flats in the middle of the pins, then use thread lock on the set screws
Maybe it's partially come out and is creating drag which can explain chewing through belts
eunique is offline
Old 01-28-2013, 02:20 PM
  #1296
pickled's Avatar
do you have the washers under the rear pulley mount
pickled is offline
Old 01-28-2013, 03:08 PM
  #1297
I'd agree with pickled and make sure you have some washers under the rear pulley mount. If you do, you can also had some washers under the center tensioner to raise it a bit. I did this recently and it helped quite a bit
mrjfang is offline
Old 01-28-2013, 08:21 PM
  #1298
spring71's Avatar
Smile
New D3 parts are available.
FYI, Thanks.
spring71 is offline
Old 01-28-2013, 10:51 PM
  #1299
Originally Posted by spring71
New D3 parts are available.[/URL]
FYI, Thanks.
I was so excited to see the pullies! but.. no 22T or 13T unfortunately. Next time!
mrjfang is offline
Old 01-28-2013, 11:34 PM
  #1300
yes, me too..i don't need them just since I already have full alloy pulleys..but glad they carry them.
i like ordering from them since they have decent prices and close here with fast shipping.
eunique is offline
Old 01-29-2013, 01:18 AM
  #1301
My Speed Passion Reventon Pro is working...Hopefully get a chance to get to drift track to get some practice in and get a feel for how it goes
Along with the Speed Passion V3 10.5T motor
eunique is offline
  #1302
Here
eunique is offline
Old 01-29-2013, 01:42 AM
  #1303
Cloaked's Avatar
Got my HPI T-Drifts today and mounted them to my Topline +8mm wheels.
Made the car alot more consistent and I found it alot easier to get the slow drifts going.
I think now my problem is lack of motor RPM, its a very fine line at the moment. The 13.5T should fix that.
Cloaked is offline
Old 01-29-2013, 04:15 AM
  #1304
pickled's Avatar
I'm ordering one tomorrow
what motor are you running now?
pickled is offline
Old 01-29-2013, 07:05 AM
  #1305
Woo finally caught up with this decade. Got myself a sensored brushless setup!! (coming from a silver can brushed motor)
The goodies I got in the mail were a 120a esc from hobbyking (exact copy of the hobbywing 120a) and then from hobbypartz: tacon 3 pole 8.5t motor, solar d770 servo, and a 7.2v UBEC.
The servo is insane! Especially with the 7.2 UBEC.
And the brushless setup is perfect, very fast, very smooth, just what I wanted.
Now I just have to pick up a sensored motor for the SCT, sensorless stuff isn't fun.
Highly recommended for a cheap brushless setup. Paid $35 for the esc and $35 for the motor.
Pictures (yes I know the wiring is messy! I just wanted to go drift haha):
saturnv7890 is offline
