**For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries >
Old 09-12-2013, 12:16 PM
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default **For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries
2-4000mah 90c 2 cell orion wts batteries less than 8 cycles each pack
Asking 120.00 shipped for both or 65.00 each
Pay-Pal accepted.... SOLD
Both packs will come with 1-Brass & 2 Aluminum weights.
Very high C-Rating
I paid $105 each thru A-Main Hobbies
http://www.amainhobbies.com/advanced...ords=orion+wts
This is the Team Orion "Carbon Pro" WTS 90C, 2S, 4000mAh Li-Poly Battery Pack, with tube (bullet) style output connectors. Team Orion was the first company to encase LiPo cells inside a plastic hardcase to protect them from impacts and render them more user friendly. Now Team Orion has evolved that design once more to bring you the WTS “Weight Transfer System” in combination with a World Champion winning Carbon Pro 90C 4000mAh battery.
In many of today's R/C race cars, weight distribution is an important factor in the setup of the car and racers move the battery forwards or backwards to change the weight distribution. The problem is that the size and disposition of current batteries limits the effectiveness of this setting. To remove this limitation, Team Orion has developed an all redesigned battery case that uses shorter cells and is equipped with three compartments to fit weights. Thanks to this you can not only modify the position of the battery, but also its total weight and the disposition of that weight within the battery case. For the perfect installation in your car, the Carbon Pro 90C WTS battery features two connector positions. This also allows you to shorten your ESC cables for even better efficiency. Furthermore the battery has switched battery polarities between front and rear to avoid misconnections when the battery is turned.
Attached Thumbnails **For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries-img_3407.jpg   **For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries-img_3411.jpg   **For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries-img_3410.jpg   **For Sale** 2 Orion WTS Lipos (weight transfer system)4000mah 90c batteries-img_3409.jpg
RED-LINE M03 is offline
Old 09-13-2013, 07:19 AM
TTT
Old 09-13-2013, 08:41 PM
TTT
