1/12 forum
#4082
Originally posted by stormperson
MX5- I would also seariously think about looking into the SpeedMerchant Rev. 3
Not being serious, attempting to be funny
E
#4087
YOU WILL ALL SEE THE LIGHT!!!
lol
As was said before just file/dremel/sand the battery holder, it might also be nessessary to do the same to the chassis itself. But dont do too much, keep on test fitting the batts to check.
Also another thing that could cause that, is the nuts/screws that hold in the battery tray. Make sure that they do not hit the battery, if you use any other nut besides the stock non-locking mini 4-40 or any screw that pertrudes higher than the nut you are asking for trouble. I actually dremeld the nut so that the side that faces the batts is sloped just in case (although it might be a little much, lol).
lolAs was said before just file/dremel/sand the battery holder, it might also be nessessary to do the same to the chassis itself. But dont do too much, keep on test fitting the batts to check.
#4088
the one thing i like about the quad 12 i have been running dpowell made the opening for the batt at the perfect size that requires only slight sanding to get rid of the sharp edges and the batteries sit just about flus maybe a hair under the chassis for putting the wieght low as possible!
every other car i have ever had required a lot of sanding and filing.
#4090
Originally posted by tc3xlr8er
where can you oder the quad 12.
For the time being, the Quad12 conversion is only available from me. Send me a PM or e-mail and I'll provide more information.
D.P.
#4091
HeY!!!
i have just two qeustions my freind and i are prolly going to get a rc L3 1/12 scale and we're both wondering what would be a good setup to start out w/, and also if you need a special diff to race mod???
in advanced thanks to whom ever will help.
2991Likes
